xl-7 command station 5 roms, what to do?
2009-04-22 by drpimpvandal
Well here's my problem I have 5 roms, and as we all know ony four slots. Could I install a rom, save all presets to user bank then remove that rom, insert another rom. Now the rom saved to user bank is no longer in, will sounds still be available and working in user banks? In a way this might let me use the sound from the 5th rom, but every time I save a user created preset, I'll overwrite sounds from the rom not inserted? Would this work?
Re: [xl7] xl-7 command station 5 roms, what to do?
2009-04-22 by Bob S.
No.
The ROM holds the sample of the preset you are playing.
You can do what I did, buy a Proteus 2000 or an XL1 Turbo module for 4 more ROM slots and then use the module as another sound generator for the XL-7.
Bob
El Segundo, CA
Sent: Tuesday, April 21, 2009 8:11 PM
Subject: [xl7] xl-7 command station 5 roms, what to do?
How to 'reset' to original factory setup
2009-04-22 by gary higgins
It's been a long while since I've done much with these modules-I want to set up my XL(after backup of my seq.ect) back to how it was when it was new, just the original sounds and factory seq and start fresh. Can someone refresh me on what to do or if there is a system reset button combo that will do this? Thanks
2009-04-22 by tom johnson
Sorry to say, you can't do that, the user presets are for you to tweak a sound and save it. But the original sample stays intact on the rom. If you take the rom out it just won't play. You should find an empty shell on ebay. It sounds like you have all the roms you want. But the shells cost maybe $50. I have seen quite a few on there in the past couple of months. Good luck. TOMTEL
--- On Tue, 4/21/09, drpimpvandal <drpimpvandal@...> wrote:
> From: drpimpvandal <drpimpvandal@...>
> To: xl7@yahoogroups.com
> Date: Tuesday, April 21, 2009, 11:11 PM
RE: [xl7] How to 'reset' to original factory setup
2009-04-22 by Andrew
Just hold both cursor keys at the same time while booting the system up... it'll take you to a diagnostic menu, and one of the functions is system restore... or something like that... it takes a couple minutes, but it puts everything back to square one. Make sure you back up everything... sequences, presets, arps... everything.
Date: Wed, 22 Apr 2009 12:42:48 +0000
Subject: [xl7] How to 'reset' to original factory setup
Rediscover HotmailĀ®: Now available on your iPhone or BlackBerry Check it out.
Re: [xl7] How to 'reset' to original factory setup
I think you are wanting to re-initialize. Hold down both cursor buttons when powering on. I think it is at the end like #16 ? or #17 ? But I don't know if that brings back the factory sequences or not, I have never deleted mine so. You may have to download them back after initializing. From "e-loader" which I still haven't got to work.
Good Luck, TOMTEL
--- On Wed, 4/22/09, gary higgins <heyrag@...> wrote:
> From: gary higgins <heyrag@...>
> Date: Wednesday, April 22, 2009, 8:42 AM
Flash SIMMS
2009-04-30 by gary higgins
I am looking for this memory for XL. Read something somewhere about using equivalant from modem or router?? Is there any sources for obtaining this or whatever including the emu stuff that anyone knows of that will actually work??
Re: Flash SIMMS
2009-04-30 by woodsworth1
You can get a brand new EMU FLASH SIMM from The Avenues Instruments for $314.00 (http://www.theavenuesinstruments.com) or they show up on ebay every now and then. In fact just a month ago there were 5 second hand ones up for $165 each - good deal if you got in quick, and there's one up now which is not in fact a FLASH SIMM - its just a composer ROM (so don't buy it for the $359 that's being asked).
The interface seems pretty proprietary, so I doubt that one from a modem or router would work...
