Subject: Re: [xl7] Strange problem when... and after... turning on????
Date: Monday, 16 February, 2009, 7:08 PM
I'd probably hazard a guess that it's the power supply too. Other (free) things to look for would be loose cables, bad contacts, etc. On the bright side, the power supply is a complete standalone unit that is pretty plug 'n' play if you can find the right unit. I think someone on the list was able to find a source for them. I believe the manufacturer was PowDec if I recall correctly, so I think that's where they found it.
-Aaron
----- Original Message ----
To: xl7@yahoogroups. com
Sent: Monday, February 16, 2009 9:40:14 AM
Subject: [xl7] Strange problem when... and after... turning on????
Hi peeps,
Need some help on an issue reguarding turning on and using x17.
Basically after about 2 years of having this piece of kit, i've found
it has become unstable, when i turn it on i get all the lights
flickering for a few seconds very strangely, sometimes constantly,
before eventually it loads? Then i find that its starting to crash,
after about 10-mins to 30-mins , i hoping someone can tell me what the
problem is or could be, im guessing it could be a power supply
problem, but any info or advice would be great before i attempt to
have repaired(if its bad news, then its not gonna be worth it, cost
wise)??
Thanks for reading my post
Phaze-c
