help w/ Midi A/B & prog. change
2008-12-01 by emuxl7
he110 group- thanx for this resource. I would like to use int. seq. and send same notes to ext. source with prog. change.is that possible? from what I understand- i may need to dedicate 1(or more) of the sixteen tracks to ONLY send prog. change or note on/off? (need on/off on a track for midi mixer and lights)(need prog change for external synth to double xl7 internal) this info below that Aaron provided about "multi" may be the key i'm missing....but i also thought there was something about not being able to transmit prog. change out either midi A/B. I try to keep up on posts(alot of great info) and i have been scouring the manual(with about 12 other manuals) trying to wrap my head around all the midi implementation. so many menu options in xl7 - i may be chasing my tail. :] > Also, remember that none of the sequencer tracks target any of the 'B' channels. If you're trying to sequence more than 16 channels, you'll need to set (at least) one track to be a "Multi" track - near the end of the Pattern screen. If you're just trying to use different channels (less than 16 unique, even if they're B channels), go to the same routing screen and just pick 1B (or whatever channel(s) you'd like). Finally, remember that you need to have note data recorded on the track for it to save preset info... > > -Aaron Love this machine! I have xl7 with stock card/proteus/TSCY/ensonique card and for years i have only been using it to write drum/synth sequences. Then i solo each track and record audio into Nuendo software to manipulate and add git/bass/vox/synth. I am finally going to unleash the power and get the most out of this machine with my hardware setup. XL7/ ES-1 / EA-1 / MVS-1 / K-station / Six-Track / Matrix6 / JX3P / GR-700 / MM-1 midi mixer / MX8 midi router thanx for any help and reading long post. best- Mach www.machfox.com
