[xl7] Channel 1B it's the same on each part?
2008-11-16 by Victor Yahoo
Hi, I tryed to put in different patterns on channel 1B, different instrument... I had a big surprise, when I discover that the channel 1B it is not changing with the pattern.. Is there anyone who have any ideea how to save for each pattern a different instrument on 1B channel??? Thanks Daci
2008-11-17 by Mauricio Balma
Go to Channel 1B PROGRAM CHANGE and turn it ON. --- On Sun, 11/16/08, Victor Yahoo <dacian_victor@...> wrote:
Subject: [xl7] Channel 1B it's the same on each part?
To: "xl7@yahoogroups.com" <xl7@yahoogroups.com>
Date: Sunday, November 16, 2008, 2:33 PM
channel 1B, different instrument.. .
Daci
[Non-text portions of this message have been removed]2008-11-17 by Aaron Eppolito
Also, remember that none of the sequencer tracks target any of the 'B' channels. If you're trying to sequence more than 16 channels, you'll need to set (at least) one track to be a "Multi" track - near the end of the Pattern screen. If you're just trying to use different channels (less than 16 unique, even if they're B channels), go to the same routing screen and just pick 1B (or whatever channel(s) you'd like). Finally, remember that you need to have note data recorded on the track for it to save preset info... -Aaron
----- Original Message ----
Sent: Monday, November 17, 2008 8:54:48 AM
Subject: Re: [xl7] Channel 1B it's the same on each part?
Daci
Yahoo! Groups Links2008-11-17 by Victor Yahoo
Thanks for the quick answer. I tryed to find where is it this program change for channel 1B, in MIDI??? The question is: can i have in a pattern set notes and instruments both on 1-16 C and 1-16 B? On Nov 17, 2008, at 6:54 PM, Mauricio Balma <balmaproducer@...> wrote: Go to Channel 1B PROGRAM CHANGE and turn it ON. --- On Sun, 11/16/08, Victor Yahoo <dacian_victor@...> wrote:
Daci
[Non-text portions of this message have been removed]2008-11-17 by Mauricio Balma
I think it's on the MIDI menu... You have 32 virtual tracks, but you can have only 16 triggers for them. However, you can "compress" the 16 tracks A or 16 tracks B into a single trigger with the Multi A or Multi B function. --- On Mon, 11/17/08, Victor Yahoo <dacian_victor@...> wrote:
To: "xl7@yahoogroups.com" <xl7@...m>
Date: Monday, November 17, 2008, 1:28 PM
1-16 C and 1-16 B?
On Nov 17, 2008, at 6:54 PM, Mauricio Balma <balmaproducer@ yahoo.com> wrote:
To: "xl7@yahoogroups. com" <xl7@yahoogroups. com>
Daci
[Non-text portions of this message have been removed]2008-11-17 by Victor Yahoo
Thanks for all the answers, I tryed all the solutions, but I did't succed. Well things get more complicated then i expected,... this is why i need it for: I use for live a midi keyboard, together with XL7, for lead parts... The midi key transmit only on first channel. I was thinking to transmit the midi parts on channel 1B and to change the instrument directly with the patterns. But, it seems that 1B settings and instrument does't change with the patterns. What do you think????? Daci On Nov 17, 2008, at 8:28 PM, Aaron Eppolito <synthesis77@...> wrote: Also, remember that none of the sequencer tracks target any of the 'B' channels. If you're trying to sequence more than 16 channels, you'll need to set (at least) one track to be a "Multi" track - near the end of the Pattern screen. If you're just trying to use different channels (less than 16 unique, even if they're B channels), go to the same routing screen and just pick 1B (or whatever channel(s) you'd like). Finally, remember that you need to have note data recorded on the track for it to save preset info... -Aaron
Daci
Yahoo! Groups Links
[Non-text portions of this message have been removed]2008-11-18 by steve_the_composer
I am not clear what you are trying to do. Do you want to use the pads to play live on one channel (C01A for example) and at the same time have pre-programed patterns change the presets on different channels (C02A --> C16A for example)? Also, are you performing in pattern mode or song mode? If you are using song mode, what is the setting for EVENT SOURCE Preset? Not sure the answers to these questions will help, but I thought I'd ask since none of the other advice has solved the problem. --Steve --- In xl7@yahoogroups.com, Victor Yahoo <dacian_victor@...> wrote: > > > > Thanks for all the answers, > > I tryed all the solutions, but I did't succed. > > Well things get more complicated then > i expected,... this is why i need it for: > I use for live a midi keyboard, > together with XL7, for lead parts... > The midi key transmit only on first channel. > I was thinking to transmit the midi parts > on channel 1B and to change the > instrument directly with the patterns. > > But, it seems that 1B settings and instrument > does't change with the patterns. > > What do you think????? > > Daci > > > > > > On Nov 17, 2008, at 8:28 PM, Aaron Eppolito <synthesis77@...> wrote: > > Also, remember that none of the sequencer tracks target any of the 'B' channels. If you're trying to sequence more than 16 channels, you'll need to set (at least) one track to be a "Multi" track - near the end of the Pattern screen. If you're just trying to use different channels (less than 16 unique, even if they're B channels), go to the same routing screen and just pick 1B (or whatever channel(s) you'd like). Finally, remember that you need to have note data recorded on the track for it to save preset info...
> > -Aaron > > ----- Original Message ---- > From: Mauricio Balma <balmaproducer@...> > To: xl7@yahoogroups.com > Sent: Monday, November 17, 2008 8:54:48 AM > Subject: Re: [xl7] Channel 1B it's the same on each part? > > Go to Channel 1B PROGRAM CHANGE and turn it ON. > > > > --- On Sun, 11/16/08, Victor Yahoo <dacian_victor@...> wrote: > > From: Victor Yahoo <dacian_victor@...> > Subject: [xl7] Channel 1B it's the same on each part? > To: "xl7@yahoogroups.com" <xl7@yahoogroups.com> > Date: Sunday, November 16, 2008, 2:33 PM > > Hi, > I tryed to put in different patterns on > channel 1B, different instrument.. . > I had a big surprise, when I discover that > the channel 1B it is not changing with the > pattern.. Is there anyone who have any ideea > how to save for each pattern a different > instrument on 1B channel??? > Thanks > Daci > > [Non-text portions of this message have been removed] > > ------------------------------------ > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed] >
2008-11-18 by Victor Yahoo
Well I use pre-programed patterns.
Most of the channels are full with drums
and others lines...
But also i use a external midi keyboard,
which by default can play only channel 1.
So I set to play 1B, and the ideea was
to have for different patterns set different
instruments on 1B.
I use 1B just for playing live on this external
midi keyboard. Otherwise I need to change
the instr. and volume on the stage.
Ps. In this moment instr. and volume for
1B channel remain the same for all patterns.
--Steve
> Daci
> -Aaron
> Hi,
> Thanks
> Daci
[Non-text portions of this message have been removed]2008-11-18 by Aaron Eppolito
Ahh, I see. You can do one of two things: 1 - turn Rechannelize OFF and set it to use MIDI In B 2 - leave Rechannelize ON and simply put yourself on Channel 01B What would probably work best for you going forward is to dedicate a track in the sequencer to being your "Live" track. Store a volume event (so that it will save preset info) and then leave your active track to be that one (with Rechannelize ON). This way, it will change patches for you (or not if you leave the track empty) and you'll be able to quickly switch to one of the other tracks for recording or other use. -Aaron
Sent: Tuesday, November 18, 2008 8:08:40 AM
Subject: Re: [xl7] Re: Channel 1B it's the same on each part?
and others lines...
instruments on 1B.
--Steve
> Daci
> -Aaron
> Hi,
> Thanks
> Daci
Yahoo! Groups Links
