another MP-7 problem, lost instrument selection,once power is shut off.
2008-09-20 by eric_swhite
Hello fellow Command Station users, I have been experiencing a timing problem since day one. I can copy a pattern to the next open spot, and when I go from one to the next, the start is out of time. If I do not change patterns, and let just one pattern loop, it is in perfect time. I have tried everything to stop this problem, nothing makes it work. I decided to use the MP-7 as a tone generator instead, slaved to a rock solid sequencer in a Roland MC-909. I built a pattern in the MP-7 with no sequencer info, just patch selections for the corresponding midi tracks on the MC-909. I saved the choices each time I finished a channel. I saved these sound selections 16 times on this one pattern, to be sure they were there, I switched to a different pattern, and played it, then switched back. They were still there, so I was confident I could switch it off, after six hours of work. So today I turn everything back on, and the sounds have not been remembered by the MP-7. I saved it so often, I have to wonder, WHAT is it saving when it says it's saved something? there was no sequencer data, just sound selection, and it didn't save it. All I have that it saved was the name I had given it.BIG DRAG.Why would a Multisetup be needed to stop this, when I used an empty pattern to start with? What is the point of such O.S. destuctive tendencies? This purple box has fine sounds, but is crippled by an O.S. that follows no logic.I have sequenced on Roland, Korg, Sequential, Quasi- midi, and Yamaha gear for 26 years and have never had a problem.When a programmer saves a pattern, the machine should SAVE THE PATTERN. I am very frusrated with this not working correctly. Anyone who can tell me how to do it so it works, would be like a friend indeed. I have O.S. 2.0. and I have added the XL-1 rom, and the Orch-1 rom (most of which shows sound names, but plays no sounds, another drag). Thanks for listening to me moan like a JX-8P. ESW.
