----- Original Message ----
Sent: Sunday, September 14, 2008 8:01:10 AM
Subject: Re: [xl7] Re: Keep getting not installed error on XL7 try this
This is really good news as i was about to scrap my mp7 because i was SURE i some hoe messed up the rom board. I have been trying to figure this out on mine for some time so I just have to switch those.
--- On Sun, 9/14/08, steve_the_composer <smw-mail@...> wrote:
Subject: [xl7] Re: Keep getting not installed error on XL7 try this
Date: Sunday, September 14, 2008, 1:17 PM
Bank switching involves three parameters:
ROM ID [MSB]
ROM BANK [LSB]
Program Change
MIDI Spec defines controllers 0 and 32 for bank switching; you also
need to send a program change in order for the swicth to take effect.
If you have no controllers or devices hooked up to your gear (either
hardware or software), you could still accidently switch to a bank
you don't have. That would result in the "NOT INSTALLED" message.
--Steve
--- In xl7@yahoogroups. com, "Angelo" <ace.angelo@ ...> wrote:
> when i used the roland a-33 controler to my proteus2000
> i found out when i tried to change patches
> the NOT INSTALLED would show up
> I then figured out that the controller
> was sending something to the emu that did not agree
> So then i played around with the cc32 and the cc00 buttons on the
controller
> and set them to the user bank 0 of the Emu
> and it worked
> From: Bob S.
> To: xl7@yahoogroups. com
> Sent: Saturday, September 13, 2008 6:03 PM
> Subject: Re: [xl7] Keep getting not installed error on XL7 try
this
> That's interesting info on the cc's.....how did you find that
out ?
> Bob
> El Segundo, CA
> From: Angelo
> Sent: Saturday, September 13, 2008 2:23 PM
this
> are u trying to get the sounds out through a midi controller?
> if you are make shure the cc32 is set to 0
> and the cc00 is set to 0
> or it will say not installed!!!
> will the demo song play?
> if it does you still have the sounds there
> hope this helps you
> From: phillip deverell
> Sent: Friday, September 12, 2008 3:09 PM
> The OS loads but when I try to access the XL7 rom it says "not
installed'. Then if I move the jog wheel the user presets show up
but they have no sound rom to go off of, and no sound comes out. I
think it is a software problem. Thanks for your advice, I hope I can
still fix it.
> --- On Thu, 9/11/08, Ty Rodgers <solacerodgers@ ...> wrote:
> > From: Ty Rodgers <solacerodgers@ ...>
> > Date: Thursday, September 11, 2008, 3:12 PM
> > does it say no sound rom found when you go to select a
> > sound? That happened to my mp7 and i was never able to fix
> > it. I checked everything man. sorry to hear that.
> > --- On Thu, 9/11/08, grandfunkemperor
> > <grandfunkemperor@ ...> wrote:
> > From: grandfunkemperor <grandfunkemperor@ ...>
> > Subject: [xl7] Keep getting not installed error on XL7
> > Date: Thursday, September 11, 2008, 7:13 PM
> > I have an XL7 with it's original rom and it claims it
> > is not installed, although it is. I have tried
> > loading it in every slot and I still get "not
> > installed" when trying to get at my sounds. All my
> > present and custom pattern info is still there, midi works
> > fine, just no sound. I had removed
> > it and reinstalled it when I was having startup issues and
> > now it loads fine minus the sounds.
> > Any help would be greatly appreciated. Thanks.
> > [Non-text portions of this message have been removed]
Yahoo! Groups Links
