Keep getting not installed error on XL7
2008-09-11 by grandfunkemperor
I have an XL7 with it's original rom and it claims it is not installed, although it is. I have tried
loading it in every slot and I still get "not installed" when trying to get at my sounds. All my
present and custom pattern info is still there, midi works fine, just no sound. I had removed
it and reinstalled it when I was having startup issues and now it loads fine minus the sounds.
Any help would be greatly appreciated. Thanks.
Re: [xl7] Keep getting not installed error on XL7
2008-09-11 by Ty Rodgers
does it say no sound rom found when you go to select a sound? That happened to my mp7 and i was never able to fix it. I checked everything man. sorry to hear that.
--- On Thu, 9/11/08, grandfunkemperor <grandfunkemperor@yahoo.com> wrote:
Subject: [xl7] Keep getting not installed error on XL7
Date: Thursday, September 11, 2008, 7:13 PM
2008-09-12 by phillip deverell
The OS loads but when I try to access the XL7 rom it says "not installed'. Then if I move the jog wheel the user presets show up but they have no sound rom to go off of, and no sound comes out. I think it is a software problem. Thanks for your advice, I hope I can still fix it.
--- On Thu, 9/11/08, Ty Rodgers <solacerodgers@...> wrote:
> From: Ty Rodgers <solacerodgers@...>
> Subject: Re: [xl7] Keep getting not installed error on XL7
> To: xl7@yahoogroups.com
> Date: Thursday, September 11, 2008, 3:12 PM
> <grandfunkemperor@...> wrote:
> From: grandfunkemperor <grandfunkemperor@...>
2008-09-12 by Ty Rodgers
if you fix it let me know mine does the sma ething and i have been using it as a midi controller only.
--- On Fri, 9/12/08, phillip deverell <grandfunkemperor@...> wrote:
From: phillip deverell <grandfunkemperor@yahoo.com>
Date: Friday, September 12, 2008, 7:09 PM
--- On Thu, 9/11/08, Ty Rodgers <solacerodgers@ yahoo.com> wrote:
> From: Ty Rodgers <solacerodgers@ yahoo.com>
> To: xl7@yahoogroups. com
> <grandfunkemperor@ yahoo.com> wrote:
> From: grandfunkemperor <grandfunkemperor@ yahoo.com>
2008-09-16 by fretsmax@sbcglobal.net
Are you powering a midi device into the unit while it loads?
You may be sending a signal that the unit does not understand.
  Sent: Friday, September 12, 2008 3:09 PM
