Index last updated: 2026-04-02 22:17 UTC
Can anyone help with a Tuning Issue
2008-08-14 by Keith Young
I am trying to use single note change and bulk upload and I cannot get
them to work. I thought the upload might be my checksum calculation, so
I tried getting a download to see if I could replicate the number
generated by the Proteus module, but I can't. Worse, the MIDI spec and
the Proteus manual includes different parts of the message in the
checksum calculation. I can't get the single note ones to work either
and these don't have a checksum in them so it may be wrong about what I
am expecting to happen.
If anyone has any code (or even a binary SSNC or Bulk dump) that works
I would be grateful.
Keith
Re: Can anyone help with a Tuning Issue
2008-08-15 by steve_the_composer
Hi, Keith.
I have not done this on the Proteus line, but in other software I
did (decades ago), I just added the values in the relevant locations
based on 7 bits (ie., from 0x00 to 0x7F; next number is 0x00; that
is 0x7F + 0x01 = 0x00). I then subtracted the value from 0x80 and
the result was my checksum. I just assumed all midi checksums worked
the same way. Is that the same as doing XOR?  Hmmmm. I guess it
would be, wouldn't it? The question remaining is this: Is it based
on 7 bits? (I would assume so.)
If I am right and I wanted to test it, I'd add all of the numbers
from the 7E through the 388 bytes and figure out what I have to add
to make it 0.
What happens if you do a bulk tuning dump from the front panel, add
a few numbers to the frequency values, subtract an equal number from
the checksum, and send it back to the E-Mu? (I may try this later.)
--Steve
get
calculation, so
and
either
what I
works
> Thanks,
> Keith
Just did a quick test as follows [on XL-2500]:
(1) On C-2 of USer Table 1 I changed coarse to 127 and fine to 63.
(2) I requested table 1: f0 7e 00 08 00 00 f7
Here's the first part of the dump:
F0 7E 00 08 01 00 [header]
55 73 65 72 20 54 75 6E 69 6E 67 20 30 30 30 20 [name]
7F 7E 00 [C-2]
01 00 00 [C#-2]
(3) I then changed C-2 back to its original
00 00 00
(4) Since I added 03, I subtracted 03 from the check sum.
37 became 34
(5) I then sent the dump back and since I had the table up
 on display, I saw the 127 and 63 change back to 000 and 00.
I imagine the other P2Ks should work the same way.
BTW, I seem to recall on the P2K message board a few of us discussed
tuning systems. This was a year or two ago.
I will check out the single note change.
--Steve
PS: My checksum calculation (Roland gear) was either for the
Commodore 64 or the Intel 8086/8088 and may have been in assembly
lang. I would have used an 8 bit variable, shifted left, then right
to drop the 8th bit and finally subtracted from 80h. If I ever find
the code, I will check to see if I used the XOR.
2008-08-16 by Keith Young
Its very strange. I am also seeing the values change depending on
manual adjustments in the front panel. But when I come to actually
trying to calculate from scratch, I never get the same value as they
do. I have tried every combination of the first 6 bytes (the header),
both with and without including the name, either XORing or ADDing and
trying additional subtraction from 0x80 or XORing the result with
0x7f. So I went back to my standard routine and tested it on a non-
Emu module and it worked fine. In then end I found that if I set the
checksum to 0x7f it works. It shouldn't, but it does. I think it's a
bug.
As for the Single Note Change, it is doing nothing for me. I would
expect to be able to send it and get an immediate effect when I play
the note (I don't). If I send a whole table, it works fine.
Keith
> 7F 7E 00 [C-2]
> 01 00 00 [C#-2]
> 00 00 00
> 37 became 34
discussed
> --Steve
I have just figured out the Single Note Tuning Change problem. The
manual is in error. It documents the message as a Midi Universal Non-
Realtime message (0x7e) when it should be Universal Realtime message
(0x7f). I have documented both these bugs in the SysExFaults file in
the P2K group file section.
Thanks for the help, I thought I was cracking up for a while there.
Keith
they
header),
and
a
> bug.
play
> Keith
> > 7F 7E 00 [C-2]
> > 01 00 00 [C#-2]
> > 00 00 00
> > 37 became 34
> discussed
> > --Steve
right
find
2008-08-16 by steve_the_composer
See below.
> In then end I found that if I set the checksum to 0x7f
> it works. It shouldn't, but it does. I think it's a bug.
Its by design, not a bug. In fact, its in the sysex manual somewhere
(0x7f = ignore checksum). Perhaps there were different people
working on the sysex or it was inherited or something screwy was
going on, so someone said, "Hey, let's make 0x7f a special case to
ignore checksum!"
Sorry I didn't point that out in my previosu post.
> play the note (I don't). If I send a whole table, it works fine.
I played around with it for about 10 min after doing the bulk dump
and didn't get anywhere. I am thinking perhaps the bulk tuning dump
works on tuning tables shared by the front panel and sysex, while
the single note works purely by sysex independent of front panel
changes. (There's the standard note somewhere in there to the effect
that if you change it by remotely, subsequent changes need to be
done remotely, too.)
Some footnotes that I discovered, but didn't chase too far:
(1) Tuning Table Requests (Bulk Dumps) start from 0 and actually go
to something like 59, but after 12, you just get the last tuning
table data, though if I remember correctly, the header makes it look
like there are additional table.
(2) As you noticed front panel fine = 63 corresponds with 0x7f. 62
coresponds with 0x7d, etc. You may have also noticed there is a
third byte after coarse and fine. I tried sending intermediate fine
values and third byte values. They did not get sent back with
subsequent requests.
(3) There is a keyboard tuning parameter (in the middle of the
controller parameter, I think). You may have noticed that the user
tuning tables come at the end.
So, I was thinking that the "on-the-fly" single note tunings go
somewhere (an undocumented table?) after the OS pulls (1) the
keyboard tuning value and (2) if its a user table, the user table
settings. This would make sense, esp. if the "on-the-fly" changes
affect the built-in tunings.
That's as far as I got. I didn't test this out, though. I suppose to
test it, I would use on of the built in turnings, audition some
basic riff, send a sysex with whacky single note tunings, and just
listen.
Perhaps there are three values in the user tuning tables because all
three ultimately get copied into an undocumentable table from which
we don't know if we can read/request the values.
Hmmmmmm. I love logic puzzles like this. Maybe I will try to free up
some time to test it.
--Steve
63.
> > 7F 7E 00 [C-2]
> > 01 00 00 [C#-2]
> > 00 00 00
> > 37 became 34
> discussed
> > --Steve
assembly
right
find
Thanks for figuring this out, Keith. I changed my copy of the manual.
Interesting: it says "Exclusive Real-Time sub-ID#1 = 08h" in the
description, but "Non-real time" in the format/example. The same
discrepancy is in the section on Master Volume. (I'm guess that should
also be real-time.)
BTW, the error goes back at least as far as sysex manual 2.0. Kudos to
you for finally correcting this!!!
--Steve
> Keith
