----- Original Message ----
Sent: Thursday, July 3, 2008 7:04:13 PM
Subject: [xl7] Re: USB problems w/ XP
Just to make sure then can I still backup/restore sequence data using
only a MIDI I/O connection on Windows XP without the USB?
--- In xl7@yahoogroups.com, "dwn4tupac" <dwn4tupac@...> wrote:
> well that clears that up then...thx
> N
> --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@> wrote:
> > Your OS is fine. They're checksummed on download. If it runs at
> all, it's fine.
> > From: dwn4tupac <dwn4tupac@>
> > To: xl7@yahoogroups.com
> > Sent: Wednesday, July 2, 2008 6:30:40 PM
> > I'm wondering if some of these problems aren't caused by a corrupted
> > os 2.0 update... anyone have some insight?
> > --- In xl7@yahoogroups.com, "dutchbeats" <dutchbeats@> wrote:
> > > First of all greetings to all here! I've been waiting to ask the
same
> > > question and have the exact same problem with XP. I can see all the
> > > sequences and songs in E-loader but when I try to upload a
sequence or
> > > song to my pc it says it can't do it with a red stop sign! No
> > > explanation. Also, in the MIDI setup window the only way
E-loader will
> > > bring up the XL-7's sequences is when the Sysex device ID is set
to 1
> > > but the actual device ID numbers are 0. If I change the number
to 0 to
> > > match the device numbers it won't even read the XL-7! This is
> > > supposedly a key point that the numbers should match so I'm lost.
> > > Since I will only be connecting my XL-7 to my XP PC for sequence
> > > backup/restore you guys say that I can do that with just a MIDI I/O
> > > connection and no USB? That would take a load off my mind. Cheers!
> > > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote:
> > > > PS: e-loader uses Sun's java. I mention this in case that might be
> > the
> > > > source of the problem. When you run e-loader, check the Message
> > > > Console (under the Window menu) to see if there are any signs of
> > > > problems with java. (This is a long-shot, but who knows. If you
> > have a
> > > > probper midi loop, if all settings are correct, and nothing is
> > > > filtering out sysex commands, its worth taking a peek.)
> > > > --Steve
> > Yahoo! Groups Links
Yahoo! Groups Links
