EXTERNAL MIDI CLOCK TRANSMIT ISSUE
2008-01-21 by jjcmorris57
HI FOLKS,
SEEMS LIKE THIS SHOULD BE SIMPLE ENOUGH BUT IT HAS ME STUMPED.
I USE MIDI ALMOST EXCLUSIVELY FOR THE CLOCK SO I CAN SYNC UP ALL MY
UNITS IN SERIES AND THIS HAS ALWAYS WORKED FINE UNTIL I INSERTED THE
XL-7 TO THE CHAIN.
HERE'S THE PROBLEM: THE XL-7 RECEIVES THE EXTERNAL CLOCK FROM THE MIDI
SOURCE JUST FINE BUT WILL NOT TRANSMIT THE EXTERNAL CLOCK ON TO THE
NEXT UNIT IN THE CHAIN.
THERE IS NO PROBLEM TRANSMITTING THE INTERNAL CLOCK FROM THE XL-7. SO
IF THAT WORKS WHY WON'T IT TRANSMIT THE INCOMING EXTERNAL CLOCK?
I HAVE READ THE MANUAL AND HAVE DONE THE FOLLOWING:
I'M IN MULTI-MODE (TRIED OMNI & POLY)
BASE TEMPO IS SET TO EXT.
MERGE MIDI IN TO MIDI OUT SET TO OUT A = ON, OUT B=ON (NOT SURE IF
THIS MATTERS)
TRANSMIT MIDI CLOCK IS SET TO ON.
CLEARLY I'M MISSING SOMETHING. ANY HELP WOULD BE APPRECIATED!
-JEFF
RE: [xl7] EXTERNAL MIDI CLOCK TRANSMIT ISSUE
2008-01-21 by BJM
Jeff,
I read through your description and one thing that needs to be confirmed is
whether the next unit after the XL-7, in the chain, is set to receive an
external clock.
Bruce
  _____
From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of
jjcmorris57
Sent: Monday, January 21, 2008 11:38 AM
Subject: [xl7] EXTERNAL MIDI CLOCK TRANSMIT ISSUE
HI FOLKS,
XL-7 TO THE CHAIN.
THIS MATTERS)
-JEFF
Re: EXTERNAL MIDI CLOCK TRANSMIT ISSUE
HI BRUCE,
YES IT IS. IN FACT IT RECEIVES THE "INTERNAL" CLOCK FROM THE XL-7
JUST FINE.
-JEFF
--- In xl7@yahoogroups.com, "BJM" <brujerman@...> wrote:
> Jeff,
confirmed is
receive an
> external clock.
> Bruce
>   _____
> jjcmorris57
> To: xl7@yahoogroups.com
> HI FOLKS,
THE
> XL-7 TO THE CHAIN.
MIDI
SO
> THIS MATTERS)
> -JEFF
Re: [xl7] Re: EXTERNAL MIDI CLOCK TRANSMIT ISSUE
2008-01-22 by Aaron Eppolito
Note that "Merge MIDI In to Out" does *not* echo clock.  You'll want to set up the XL-7 to slave to clock (by setting master tempo to "0/ext") and then retransmit clock (transmit MIDI clock).  Note that in general, you don't want to daisy chain clock, as you'll get lots and lots of timing slop.  Better is to get a cheap MIDI patch bay that will allow you to distribute clock.  Any old MIDI patch bay (MIDI Express, MTP AV, Unitor8, etc) you can find for cheap on eBay will do the job.
-Aaron
PS. welcome to the internet - caps lock is *not* your friend...  =)
----- Original Message ----
Sent: Monday, January 21, 2008 9:08:52 AM
Subject: [xl7] Re: EXTERNAL MIDI CLOCK TRANSMIT ISSUE
HI BRUCE,
JUST FINE.
-JEFF
> Jeff,
confirmed is
receive an
> external clock.
> Bruce
>   _____
> jjcmorris57
> HI FOLKS,
THE
> XL-7 TO THE CHAIN.
MIDI
SO
> THIS MATTERS)
> -JEFF
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
