Re: cleaning encoder
2007-11-29 by gonzinigonz
Hi Gord
Dont spray it down the sides of the shaft.
You will brake down the grease that make it smooth to turn.
Have a look at this photo (if the link works.. its in the root of the
photos section)
http://ph.groups.yahoo.com/group/xl7/photos/view/9e1e?b=14&m=s&o=0
Look where the arrows are, thats were you spray.
You dont need vey much, in fact if you apply full pressure on the
nozzle even for 1/2 second that will be way too much!
You dont really want to cover anything else in Deoxit as its a waste
and its expensive! Also you will degrease the shaft.
If you do mop it up with some toilet roll or the like.
Hope that helps :0)
Gonz
--- In xl7@yahoogroups.com, "winstonoleary" <gordwiebe@...> wrote:
> so, I'm going to have to give cleaning my encoder a try now... where
> exactly do you put the deoxit? Down the shaft, on the underside? I
> really don't know!
> thanks,
> Gord
