My PX 7 Has Frozen
2007-10-03 by Steve Humphries
I was wondering if anyone can help with this. I was playing a patch from my PX7 when suddenly there was no sound. I turned the unit off and then on again and all the led's light up but then everything seems to freeze. Any help would be much appreciated. Thanks Steve
2007-10-03 by Bob S.
The most common problem with the aging or moved xX-x series keyboard/module/command station is the seating of the sound ROM(s). My first recommendation, since power seems to be OK, is to re-seat the ROM. While the unit is open, it wouldn't hurt to verify the seating of internal interconnecting cable. Don't forget to remove turn make sure the unit is unplugged or the main unit power switch is off before working on the unit. Try this first and we can take the next step depending on that outcome. Bob El Segundo, CA
----- Original Message ----- From: Steve Humphries To: xl7@yahoogroups.com Sent: Wednesday, October 03, 2007 2:35 AM Subject: [xl7] My PX 7 Has Frozen I was wondering if anyone can help with this. I was playing a patch from my PX7 when suddenly there was no sound. I turned the unit off and then on again and all the led's light up but then everything seems to freeze. Any help would be much appreciated. Thanks Steve [Non-text portions of this message have been removed]
2007-10-03 by Stephen Humphries
Hi Bob Thanks for your advice with regards to my PX7 I've had a go at removing and then reseating the rom boards as well as checking for any loose cables. I have power with all the led's showing on switch on but then the unit just freezes. Regards Steve
Sent: Wednesday, 3 October, 2007 3:56:12 PM
Subject: Re: [xl7] My PX 7 Has Frozen
The most common problem with the aging or moved xX-x series keyboard/module/ command station is the seating of the sound ROM(s). My first recommendation, since power seems to be OK, is to re-seat the ROM. While the unit is open, it wouldn't hurt to verify the seating of internal interconnecting cable. Don't forget to remove turn make sure the unit is unplugged or the main unit power switch is off before working on the unit.
Bob
El Segundo, CA
To: xl7@yahoogroups. com
Steve
___________________________________________________________
Yahoo! Answers - Got a question? Someone out there knows the answer. Try it
now.
http://uk.answers.yahoo.com/
[Non-text portions of this message have been removed]2007-10-04 by Bob S.
Hi Steve I would try to see if you can enter diagnostics mode or if the boot sequence is stopped right at the hardware reset stage. Diagnostics mode can be entered by holding down the right and left cursor arrow keys while powering up the unit. See posts 18806 & 18812 for more info. If you can't get into diagnostics mode, it is probably a hardware problem that won't be solved by a factory reset or reloading of the OS.... Any others listening have had a similar past experience......frozen on boot with all LEDs on? Bob El Segundo, CA
----- Original Message ----- From: Stephen Humphries To: xl7@yahoogroups.com Sent: Wednesday, October 03, 2007 8:50 AM Subject: Re: [xl7] My PX 7 Has Frozen Hi Bob Thanks for your advice with regards to my PX7 I've had a go at removing and then reseating the rom boards as well as checking for any loose cables. I have power with all the led's showing on switch on but then the unit just freezes. Regards Steve ----- Original Message ---- From: Bob S. <tttsystems@...> To: xl7@yahoogroups.com Sent: Wednesday, 3 October, 2007 3:56:12 PM Subject: Re: [xl7] My PX 7 Has Frozen The most common problem with the aging or moved xX-x series keyboard/module/ command station is the seating of the sound ROM(s). My first recommendation, since power seems to be OK, is to re-seat the ROM. While the unit is open, it wouldn't hurt to verify the seating of internal interconnecting cable. Don't forget to remove turn make sure the unit is unplugged or the main unit power switch is off before working on the unit. Try this first and we can take the next step depending on that outcome. Bob El Segundo, CA ----- Original Message ----- From: Steve Humphries To: xl7@yahoogroups. com Sent: Wednesday, October 03, 2007 2:35 AM Subject: [xl7] My PX 7 Has Frozen I was wondering if anyone can help with this. I was playing a patch from my PX7 when suddenly there was no sound. I turned the unit off and then on again and all the led's light up but then everything seems to freeze. Any help would be much appreciated. Thanks Steve [Non-text portions of this message have been removed] __________________________________________________________ Yahoo! Answers - Got a question? Someone out there knows the answer. Try it now. http://uk.answers.yahoo.com/ [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2007-10-04 by Stephen Humphries
Hi Bob I've tried to enter the diagnostic stage by holding the cursor buttons but my unit is still frozen. I'm going to send it off for repair. Thanks for your help. Regards Steve
Sent: Thursday, 4 October, 2007 2:59:01 PM
Hi Steve
Any others listening have had a similar past experience.. ....frozen on boot with all LEDs on?
Bob
El Segundo, CA
Hi Bob
Regards
Steve
Bob
El Segundo, CA
Steve
____________ _________ _________ _________ _________ _________ _
now.
http://uk.answers. yahoo.com/
Want ideas for reducing your carbon footprint? Visit Yahoo! For Good http://uk.promotions.yahoo.com/forgood/environment.html
[Non-text portions of this message have been removed]2007-10-05 by Bob S.
Good luck!
----- Original Message ----- From: Stephen Humphries To: xl7@yahoogroups.com Sent: Thursday, October 04, 2007 4:31 PM Subject: Re: [xl7] My PX 7 Has Frozen Hi Bob I've tried to enter the diagnostic stage by holding the cursor buttons but my unit is still frozen. I'm going to send it off for repair. Thanks for your help. Regards Steve ----- Original Message ---- From: Bob S. <tttsystems@...> To: xl7@yahoogroups.com Sent: Thursday, 4 October, 2007 2:59:01 PM Subject: Re: [xl7] My PX 7 Has Frozen Hi Steve I would try to see if you can enter diagnostics mode or if the boot sequence is stopped right at the hardware reset stage. Diagnostics mode can be entered by holding down the right and left cursor arrow keys while powering up the unit. See posts 18806 & 18812 for more info. If you can't get into diagnostics mode, it is probably a hardware problem that won't be solved by a factory reset or reloading of the OS.... Any others listening have had a similar past experience.. ....frozen on boot with all LEDs on? Bob El Segundo, CA ----- Original Message ----- From: Stephen Humphries To: xl7@yahoogroups. com Sent: Wednesday, October 03, 2007 8:50 AM Subject: Re: [xl7] My PX 7 Has Frozen Hi Bob Thanks for your advice with regards to my PX7 I've had a go at removing and then reseating the rom boards as well as checking for any loose cables. I have power with all the led's showing on switch on but then the unit just freezes. Regards Steve ----- Original Message ---- From: Bob S. <tttsystems@earthlin k.net> To: xl7@yahoogroups. com Sent: Wednesday, 3 October, 2007 3:56:12 PM Subject: Re: [xl7] My PX 7 Has Frozen The most common problem with the aging or moved xX-x series keyboard/module/ command station is the seating of the sound ROM(s). My first recommendation, since power seems to be OK, is to re-seat the ROM. While the unit is open, it wouldn't hurt to verify the seating of internal interconnecting cable. Don't forget to remove turn make sure the unit is unplugged or the main unit power switch is off before working on the unit. Try this first and we can take the next step depending on that outcome. Bob El Segundo, CA ----- Original Message ----- From: Steve Humphries To: xl7@yahoogroups. com Sent: Wednesday, October 03, 2007 2:35 AM Subject: [xl7] My PX 7 Has Frozen I was wondering if anyone can help with this. I was playing a patch from my PX7 when suddenly there was no sound. I turned the unit off and then on again and all the led's light up but then everything seems to freeze. Any help would be much appreciated. Thanks Steve [Non-text portions of this message have been removed] ____________ _________ _________ _________ _________ _________ _ Yahoo! Answers - Got a question? Someone out there knows the answer. Try it now. http://uk.answers. yahoo.com/ [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] __________________________________________________________ Want ideas for reducing your carbon footprint? Visit Yahoo! For Good http://uk.promotions.yahoo.com/forgood/environment.html [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2007-10-15 by hymen_blaster
In my case, I apparently bricked my XL-7 while, oddly enough, en route to the repair shop to fix the data encoder. It worked at home; I put it in my car and drove a mile to the shop and now it no longer works. It doesn't really turn on anymore. The LCD screen just flashes with some black boxes. No other lights turn on. All roms seem to be in place. but hey, good thing this happened now before my liveset next month :)
2007-10-15 by Chris
I have had this as well, but then i made sure that the cables connecting the boards were seated properly (which seemed to be fine) but when i then closed the case and tried it again my mp-7 booted up without any issue. this is now about a year ago and i've had no further problems.. chris
-----Original Message----- From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of hymen_blaster Sent: Montag, 15. Oktober 2007 20:23 To: xl7@yahoogroups.com Subject: [xl7] Re: My PX 7 Has Frozen In my case, I apparently bricked my XL-7 while, oddly enough, en route to the repair shop to fix the data encoder. It worked at home; I put it in my car and drove a mile to the shop and now it no longer works. It doesn't really turn on anymore. The LCD screen just flashes with some black boxes. No other lights turn on. All roms seem to be in place. but hey, good thing this happened now before my liveset next month :) [Non-text portions of this message have been removed]
2007-10-16 by hymen_blaster
--- In xl7@yahoogroups.com, "Chris " <cdh79@...> wrote: > > I have had this as well, but then i made sure that the cables connecting > the boards were seated properly (which seemed to be fine) but when i > then closed the case and tried it again my mp-7 booted up without any > issue. > > this is now about a year ago and i've had no further problems.. > > chris I just finished doing this and it's *almost* the same thing. I say almost because it blinks on and off a few times then "Loading..." appears on the LCD. The LCD is flickering like crazy as if power is fluctuating. It finally just shuts off completely after a few seconds of flickering. I've got a different power supply ripped out of an MP-7 on the way. It's a longshot, but maybe that's the issue.
2007-10-19 by hymen_blaster
For anyone that cares, my problem did indeed turn out to be the power supply. I replaced it and everything is working fine now. I hope this helps someone at some point :)
2007-10-20 by gonzinigonz
Where did you manage to get a replacement? Also was it expensive? --- In xl7@yahoogroups.com, "hymen_blaster" <japxrf@...> wrote:
> > For anyone that cares, my problem did indeed turn out to be the power > supply. I replaced it and everything is working fine now. > > I hope this helps someone at some point :) >
2007-10-20 by hymen_blaster
I found someone selling parts from a broken command station on eBay. It wasn't too bad: $25 USD.
2007-10-20 by Bob S.
a steal !
----- Original Message ----- From: hymen_blaster To: xl7@yahoogroups.com Sent: Saturday, October 20, 2007 10:06 AM Subject: [xl7] Re: My PX 7 Has Frozen I found someone selling parts from a broken command station on eBay. It wasn't too bad: $25 USD. [Non-text portions of this message have been removed]
Good skills ;o) I looked for someone here in the UK and found proberly the last one at a new price of £80 odd pounds, so thats about $164. If anyone wants to send broken SMPS's to me l'll have a go at repairing them for them. Im sure theres a common fault with these. --- In xl7@yahoogroups.com, "Bob S." <tttsystems@...> wrote: > > a steal ! > > > > ----- Original Message ----- > From: hymen_blaster > To: xl7@yahoogroups.com > Sent: Saturday, October 20, 2007 10:06 AM > Subject: [xl7] Re: My PX 7 Has Frozen > > > I found someone selling parts from a broken command station on eBay. It
> wasn't too bad: $25 USD. > > > > > > [Non-text portions of this message have been removed] >
