[xl7] yay... UPS have been!
2007-07-26 by moose
> Yep, MIDI Clock transmit is in the MIDI menu.  As far as factory
> reset,  make sure that if you boot up in diagnostics mode to
> reset that you choose the "EXCEPT SEQ" option, otherwise you'll
> lose all sequences, factory or otherwise.
>-Aaron
thanks aaron, i rechecked the midi menu and there it was.  i must have missed it the first time thru.
anyways, i turned off that option & the midi message light went off...  as expected!
thanks
moose @ midizoo
