me again , sorry !
me again , sorry !
2002-02-17 by ph.demoor@free.fr
Hello ; I said I loved the sounds of this box but I must say it takes
a hell of a time to understand how to make it work properly !!
So... I don't like to ask help again but I'm stuck and so frustrated
not being able to think about music ...I'll stop moaning 'cos I know
there must be a (simple)answer somewhere and I'll feel ashame again!
Here's my problem : I want to be able to play the patterns
 (cha.1 to 16 A) and at the same time adding something from my guitar
-controller (GR30) which is supposed to play on channel 1B...in the
midi menu I put  omni enable, receive prog.change on for theA and off
for theB channel, rechannelize midi in :off , merge midi : off and
tried so many alternatives to get to the same problem : the pattern is
playing fine but when I change the tracks/chan. the sounds (of the
snare or the bass drum )are changing accidently as well  so playing a
syn(or any)sound on chan.1b add suddenly a ton of reverb on the other
(rythmic) channels !   Au secours!!
Re: [xl7] me again , sorry !
2002-02-19 by Aaron Eppolito
In omni mode, it uses preset FX.  You really should be in multi mode.
To get the midi in port up to the B channels, go to the MIDI IN CHANNELS
screen (5th screen in the MIDI menu) and select "B".  Now everything coming
in the midi port will go to channels 1-16B instead of A.
-Aaron
Thank you !
2002-02-19 by philou6fr
mode.
CHANNELS
everything coming
> -Aaron
> > >Aaron ; you're wonderful !! I know I still have to spend some
time to get around of these endless possibilities; still , it's worth
it ! Thank you .> >
> > xl7-unsubscribe@y...
