mp7 bug. does a sound get stuck on for a while ?
2007-02-20 by romildagreat
Sometimes when im making a track i hit a key and that sound just stays
and keeps buzzing for a long time and no matter what i press its just
stuck. i cant press play or anything its like it freezes up.  any
solutions?
Re: [xl7] mp7 bug. does a sound get stuck on for a while ?
2007-02-21 by Bob S.
New setup ?
Possible MIDI loop.  Or a problem with your controller.  Try a different configuration or controller...
Bob
El Segundo, CA
  Sent: Tuesday, February 20, 2007 2:49 PM
  Subject: [xl7] mp7 bug. does a sound get stuck on for a while ?
  solutions?
Re: mp7 bug. does a sound get stuck on for a while ?
2007-02-21 by steve_the_composer
(1) Are the presets from ROM or User RAM?
(2) If they are from User RAM, were they originally designed for a
ROM that you don't have?
(3) If so, make sure all the peset parameters are valid.*
(I have had a lock up like the one you describe when adapting
presets from different ROMS.)
*Scroll through Preset parameters an look for ????.
examples:
LINK 1 PRESET ??? [and LINK 2 PRESET ???]
off
ARPEGGIATOR ????
Pattern 02^0 (not instld)
AUDITIION RIFF ????
Plays:(not installed)
Hope this helps.
--Steve
stays
just
> solutions?
Re: [xl7] Re: mp7 bug. does a sound get stuck on for a while ?
2007-02-21 by ROY MILLER
im a lil lost but what i can say is that I installed a protozoa rom and its happened more since then. I mean it would happen without it but it happens a lil more now.
steve_the_composer <smw-mail@...> wrote:          (1) Are the presets from ROM or User RAM?
examples:
off
ARPEGGIATOR ????
AUDITIION RIFF ????
Hope this helps.
--Steve
stays
just
> solutions?
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
2007-02-21 by vermis_rex
I've had this happen (or something very similar) on a few occasions
with my PX-7.  I think it is a MIDI problem, as it (my problem) gets
solved every time with a MIDI-all-off (pressing MIDI and HOME/ENTER at
the same time).
And, as mentioned, it could be my controller (because at the moment
I'm using an old CZ-101 I had lying around).
--- In xl7@yahoogroups.com, "Bob S." <tttsystems@...> wrote:
> New setup ?
> Bob
> El Segundo, CA
>   ----- Original Message -----
>   From: romildagreat
>   To: xl7@yahoogroups.com
stays
>   solutions?
2007-02-22 by steve_the_composer
I agree with others' diagnostic suggestions:
--Make sure it is not a midi loop lockup.
--Try HOME/ENTER + MIDI (midi reset).
Also, what OS do you have? If not 2.0, try upgrading the OS.
In case those don't clear up the problem, let me clarify my previous
steps:
(1a) When you experience this kind of lock up, can you tell which
preset(s) are in use at that moment?
(1b) If you know which presets are in use when the problem occurs,
look to see if they are from ROM [eg, P/123] or User RAM [User].
(2) [If they are from User RAM, go to Step 3. If not, you could try
testing the ROMS via diagnostics mode, but that seems like a long
shot since you are able to use the ROMS.]
(3) Select one of the User Presets and check presets:
(3a) Press Edit Preset.
(3b) Scroll through the Preset parameters and look for question marks
(??? or ????) in the display, such as the following:
LINK 1 PRESET ???
off
ARPEGGIATOR ????
[Make sure to check the Pattern page in the ARPEGGIATOR menu]
AUDITIION RIFF ????
(4) If you have parameters with question marks, change them to valid
settings (no question marks).
Again, this may not be your problem; I suggest it because I have had
those symptoms with this problem.
Hope this clarifies my previous post.
--Steve
PS: I doubt the problem is due to a bad ROM, but it couldn't hurt to
do some diagnostics:
(1) Hold both cursor buttons down and power up the E-Mu to enter
diagnostics mode.
DO >>**NOT**<< INITIALIZE DATA UNLESS YOU WANT TO WIPE OUT ALL USER
DATA (including all patterns and all user presets).
I can't emphasize this enough:
If you initialize data in Diagnostics mode, YOU WILL LOOSE USER
PRESETS AND USER SEQUENCES (PATTERNS AND SONGS).
(If you only want to wipe out all User Presets, there is a
diagnostics option for that.)
(2) Run RAM Test, Sound Rom Test for each slot in which you have a
ROM, and Sound Data CRC Test. (The RAM and Rom tests should pass; the
CRC test should give to a number. You don't want to see the
word "bad" as in "bad CRC" or something like that.)
(3) When done, select Reboot option.
Again, the problem doesn't sound like a bad ROM, but it couldn't hurt
to check.
> examples:
> off
> ARPEGGIATOR ????
> AUDITIION RIFF ????
> Hope this helps.
> --Steve
2007-02-22 by ROY MILLER
yeah this is what it is.ROM [eg, P/123] imma try out what u said. i have my mp7 on v2 but i just installed the protozoa so does that rom have to say v2 also.
steve_the_composer <smw-mail@...> wrote:          I agree with others' diagnostic suggestions:
steps:
LINK 1 PRESET ???
off
ARPEGGIATOR ????
AUDITIION RIFF ????
--Steve
diagnostics mode.
to check.
> examples:
> off
> ARPEGGIATOR ????
> AUDITIION RIFF ????
> Hope this helps.
> --Steve
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
2007-02-22 by Bob S.
Don't understand a word you said Roy !
Bob
El Segundo, CA
  Sent: Thursday, February 22, 2007 10:25 AM
  Subject: Re: [xl7] Re: mp7 bug. does a sound get stuck on for a while ?
  steps:
  LINK 1 PRESET ???
  off
  ARPEGGIATOR ????
  AUDITIION RIFF ????
  --Steve
  diagnostics mode.
  to check.
  > examples:
  > off
  > ARPEGGIATOR ????
  > AUDITIION RIFF ????
  > Hope this helps.
  > --Steve
2007-02-25 by ROY MILLER
I know I was basically just stating that I had the  protozoa rom installed in the mp-7. and I thought that the problem was coming from the protozoa rom. but I think its basically coming from any of the led sounds. Im going to try what u said I havent had the problem in a while though.
"Bob S." <tttsystems@...> wrote:          Don't understand a word you said Roy !
Bob
El Segundo, CA
steps:
LINK 1 PRESET ???
off
ARPEGGIATOR ????
AUDITIION RIFF ????
--Steve
diagnostics mode.
to check.
> examples:
> off
> ARPEGGIATOR ????
> AUDITIION RIFF ????
> Hope this helps.
> --Steve
Sucker-punch spam with award-winning protection.
 Try the free Yahoo! Mail Beta.
2007-02-25 by steve_the_composer
Glad to hear you haven't had the problem in a while. --Steve
though.
