tempo changes
2007-02-19 by pillmover
tempo changes aren't working when i link patterns or when i play them in song mode on my machine.
2007-02-19 by vermis_rex
--- In xl7@yahoogroups.com, "pillmover" <pillmover@...> wrote: > > tempo changes aren't working when i link patterns or when i play them > in song mode on my machine. > In the MIDI menu, the second item is about chained pattern tempo, and can be set to either "keep constant tempo" or "change to new tempo". Which is your system set to?
--- In xl7@yahoogroups.com, "vermis_rex" <vermis_rex@...> wrote: > > --- In xl7@yahoogroups.com, "pillmover" <pillmover@> wrote: > > > > tempo changes aren't working when i link patterns or when i play them > > in song mode on my machine. > > > > > In the MIDI menu, the second item is about chained pattern tempo, and > can be set to either "keep constant tempo" or "change to new tempo". > Which is your system set to? > it doesn't give me that option. i can only set the base tempo.
2007-02-20 by Aaron Eppolito
He meant in the SONG menu, 2nd screen "EVENT SOURCE", 1st item "tempo:". Choose "all patterns" (if you want it to change every patter) or "1st pattern" (if you want just the first pattern's tempo. -Aaron > > --- In xl7@yahoogroups.com, "pillmover" <pillmover@> wrote: > > > tempo changes aren't working when i link patterns or when i play > > > them in song mode on my machine. > --- In xl7@yahoogroups.com, "vermis_rex" <vermis_rex@...> wrote: > > In the MIDI menu, the second item is about chained pattern tempo, > > and can be set to either "keep constant tempo" or "change to > > new tempo". > > Which is your system set to? --- pillmover <pillmover@...> wrote: > it doesn't give me that option. i can only set the base tempo. ____________________________________________________________________________________ Get your own web address. Have a HUGE year through Yahoo! Small Business. http://smallbusiness.yahoo.com/domains/?p=BESTDEAL
2007-02-20 by soundcrafter
> > > it doesn't give me that option. i can only set the base tempo. > Sounds like you don't have OS 2.0... that option only became available with that OS update
I'm pretty sure that's been in there from the beginning. However, as I mentioned, it's not in the MIDI menu, it's in the SONG menu (which makes sense, cause it's about where the *song* gets its tempo from). =) --- soundcrafter <aurastar@...> wrote: > > it doesn't give me that option. i can only set the base tempo. > > Sounds like you don't have OS 2.0... that option only became > available with that OS update ____________________________________________________________________________________ Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games. http://games.yahoo.com/games/front
2007-02-20 by pillmover
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@...> wrote: > > I'm pretty sure that's been in there from the beginning. However, as I > mentioned, it's not in the MIDI menu, it's in the SONG menu (which > makes sense, cause it's about where the *song* gets its tempo from). > =) > > --- soundcrafter <aurastar@...> wrote: > > > it doesn't give me that option. i can only set the base tempo. > > > > Sounds like you don't have OS 2.0... that option only became > > available with that OS update > > > right. it's not os 2, it's version 1.31. i'll just work it all out in song mode for now. thanx a lot. > _____________________________________________________________________ _______________
> Bored stiff? Loosen up... > Download and play hundreds of games for free on Yahoo! Games. > http://games.yahoo.com/games/front >
Ahhh, you're right. I forgot about that feature. I was thinking about the song mode the whole time. But yeah, if you've got 1.31, you should totally get 2.00. It's free and chock full o' goodness. -Aaron > > > it doesn't give me that option. i can only set the base tempo. > > Sounds like you don't have OS 2.0... that option only became > > available with that OS update > right. it's not os 2, it's version 1.31. i'll just work it all > out in song mode for now. thanx a lot. ____________________________________________________________________________________ 8:00? 8:25? 8:40? Find a flick in no time with the Yahoo! Search movie showtime shortcut. http://tools.search.yahoo.com/shortcuts/#news
2007-02-21 by PLASTICEFX@aol.com
Unless you're a Mac man. then you're screwed!! plastic ;-P
-----Original Message----- From: synthesis77@... To: xl7@yahoogroups.com Sent: Tue, 20 Feb 2007 6:37 PM Subject: Re: [xl7] Re: tempo changes Ahhh, you're right. I forgot about that feature. I was thinking about the song mode the whole time. But yeah, if you've got 1.31, you should totally get 2.00. It's free and chock full o' goodness. -Aaron > > > it doesn't give me that option. i can only set the base tempo. > > Sounds like you don't have OS 2.0... that option only became > > available with that OS update > right. it's not os 2, it's version 1.31. i'll just work it all > out in song mode for now. thanx a lot. __________________________________________________________ 8:00? 8:25? 8:40? Find a flick in no time with the Yahoo! Search movie showtime shortcut. http://tools.search.yahoo.com/shortcuts/#news ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed]
2007-02-21 by Aaron Eppolito
Yeah. You knew I work at Apple now, right? =) Has anyone tried using E-Loader under parallels yet? > Unless you're a Mac man. then you're screwed!! > > plastic ;-P > But yeah, if you've got 1.31, you should > totally get 2.00. It's free and chock full o' goodness. > > -Aaron ____________________________________________________________________________________ Don't pick lemons. See all the new 2007 cars at Yahoo! Autos. http://autos.yahoo.com/new_cars.html
2007-02-21 by vermis_rex
D'oh! Sorry, I was assuming you had the same OS. See, I'm using a PX-7, and it shipped with OS 2.0 I keep forgetting the other Command Stations shipped with the older OS. --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@...> wrote: > > Ahhh, you're right. I forgot about that feature. I was thinking about > the song mode the whole time. But yeah, if you've got 1.31, you should > totally get 2.00. It's free and chock full o' goodness. > > -Aaron > > > > > it doesn't give me that option. i can only set the base tempo. > > > > Sounds like you don't have OS 2.0... that option only became > > > available with that OS update > > > right. it's not os 2, it's version 1.31. i'll just work it all > > out in song mode for now. thanx a lot. > > > > ____________________________________________________________________________________
> 8:00? 8:25? 8:40? Find a flick in no time > with the Yahoo! Search movie showtime shortcut. > http://tools.search.yahoo.com/shortcuts/#news >
2007-02-23 by robotchas
Hmmm, yeah, I'd be very curious to know if E-Loader works with Parallels. Though I loathe the idea of having anything from Microsoft installed on my system, even in a VM. Upgrading to 2.00 is a must! There are a lot of invaluable new features and it's rock solid. --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@...> wrote:
> > Yeah. You knew I work at Apple now, right? =) > Has anyone tried using E-Loader under parallels yet? > > > Unless you're a Mac man. then you're screwed!! > > > > plastic ;-P > > > > But yeah, if you've got 1.31, you should > > totally get 2.00. It's free and chock full o' goodness. > > > > -Aaron > > > > ____________________________________________________________________________________ > Don't pick lemons. > See all the new 2007 cars at Yahoo! Autos. > http://autos.yahoo.com/new_cars.html >
2007-02-23 by PLASTICEFX@aol.com
i'd love to have 2.0. tell me how i can install it on a mac G4 powerbook running tiger (mac os X 10.4). aaron? thx kidz... plastic ;-)
-----Original Message----- From: robotchas@... To: xl7@yahoogroups.com Sent: Fri, 23 Feb 2007 12:34 PM Subject: [xl7] Re: tempo changes Hmmm, yeah, I'd be very curious to know if E-Loader works with Parallels. Though I loathe the idea of having anything from Microsoft installed on my system, even in a VM. Upgrading to 2.00 is a must! There are a lot of invaluable new features and it's rock solid. --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@...> wrote: > > Yeah. You knew I work at Apple now, right? =) > Has anyone tried using E-Loader under parallels yet? > > > Unless you're a Mac man. then you're screwed!! > > > > plastic ;-P > > > > But yeah, if you've got 1.31, you should > > totally get 2.00. It's free and chock full o' goodness. > > > > -Aaron > > > > __________________________________________________________ > Don't pick lemons. > See all the new 2007 cars at Yahoo! Autos. > http://autos.yahoo.com/new_cars.html > ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed]
2007-02-24 by steve lewis
I do not wish for any more emails, thank you Steve Lewis --------------------------------- The all-new Yahoo! Mail goes wherever you go - free your email address from your Internet provider. [Non-text portions of this message have been removed]
2007-02-24 by Bob S.
You have to do it yourself.......see the link at the bottom of the emails.....
----- Original Message ----- From: steve lewis To: xl7@yahoogroups.com Sent: Saturday, February 24, 2007 6:09 AM Subject: [xl7] Please unsubscribe me I do not wish for any more emails, thank you Steve Lewis --------------------------------- The all-new Yahoo! Mail goes wherever you go - free your email address from your Internet provider. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
