Randomize/Humanize velocity, LFOs -> External gear?
2007-01-06 by soundcrafter
Another one for the group...
I would like to give some of my drum parts a slightly more "human"
feel by adding a little bit of random variation to the velocity.  I
swear that the XL7 has a function for this, but I can't seem to find
it right now... I don't know if I'm tired or just confused :)
I can do this with patch cords somehow, I'm sure... but will a
patchcord setup actually vary velocity on pre-recorded notes being
sent to external gear? Or notes recorded in grid mode?
Also, just for verification, there's no way to have the LFOs/envelopes
on the XL sent to external gear via MIDI - they are just internal,
correct?  There definitely doesn't seem to be any direct way...
D
Re: Randomize/Humanize velocity, LFOs -> External gear?
2007-01-06 by vermis_rex
As far as I know, the patch-cords, LFOs and envelopes are strictly
internal, and won't send any data over MIDI.  There's no way to route
any of them to the MIDI outs at all.
(although it would be a damn useful feature to have, especially if it
could be added to the patch-cord modulation destinations as the MIDI
A-P controllers)
AL
(PX-7 owner)
> Thanks
> D
Re: [xl7] Re: Randomize/Humanize velocity, LFOs -> External gear?
2007-01-06 by Bob S.
See page 172 of the manual (I am using the PX7 manual) for random sources for patch cords....there is key random 1 & 2 (static while key is depressed), filtered white & pink noise sources (dynamic) & crossfade random that will generate the same random value for all 4 layers.....
Bob
El Segundo, CA
  Sent: Saturday, January 06, 2007 8:34 AM
  Subject: [xl7] Re: Randomize/Humanize velocity, LFOs -> External gear?
  A-P controllers)
  AL
  (PX-7 owner)
  > Thanks
  > D
Yep, that's what I thought... thanks Al!
> A-P controllers)
> AL
> (PX-7 owner)
Yes, I found that this morning after getting a bit of sleep :)  I was
just thinking that there was a "humanize" function on the XL, and
there isn't - I was just too tired to still be in the studio.
Another point I should mention is that I'm trying to accomplish this
on a external piece of equipment.  I have a Blank Preset that I assign
to tracks that will be controlling external gear - Instrument is set
to "none" on all layers.  So, if I assign, for example, Xfade Random -
> Key Vel on this blank preset, and then re-record that track, the
changes in velocity should be recorded as part of the track, and
therefore passed on to my drum machine?  What about if I am entering
the notes in Grid mode?
D
layers.....
> Bob
> El Segundo, CA
2007-01-06 by robotchas
It's not really practical to send LFO or envelope information over
MIDI, since the update rate would have to be pretty high, which would
clog the MIDI bandwidth (similar to sending lots of aftertouch).
What WOULD be cool is the ability to route LFOs, envelopes, tracking
generators, etc, to internal sequencer tracks, so you could modulate
velocity, pitch, duration, and timing. Self-modulation is one of the
cooler things that analog sequencers can do that I'd like to see
incorporated into digital pattern-based MIDI sequencers.
> A-P controllers)
> AL
> (PX-7 owner)
LFOs/envelopes
> > Thanks
> > D
Key Vel is a Source but not a Destination, so there's no way to do
this mod routing. Also, while the XL7 sequencer and synth engine share
the same box and interface, they're essentially separate (I found this
out playing with arps on tracks set to "ext" - the arps are part of
the synth, not the sequencer, so they only work when the sequencer or
other note source is routed through the synth). MIDI data goes from
sequencer to synth, but not the other way around.
The solution is to build the randomization into the synth or sampler
or whatever is the target of your sequencer track (unfortunately, this
probably means you can't randomly vary the timing). While the XL7
doesn't have a "humanize" function, being able to create your own
"humanization" using the sources Bob mentions is more powerful and
flexible. If your other synth doesn't have these capabilities, you may
be able to use a random LFO or something.
> Thanks
> D
> layers.....
> > Bob
> > El Segundo, CA
Sending Arps to External Gear: How to make it happen
2007-01-07 by steve_the_composer
--- In xl7@yahoogroups.com, "robotchas" <robotchas@...> wrote:
> the arps are part of the synth, not the sequencer,
In the ARP menu system, ARP/RIFF MIDI OUT needs to be set to
either "transmit arps" or "transmit both" [arps and riffs]. This
routes the arps to external gear.
I just tested it in live mode: it works on my keyboard--->XL-2500--->M-
GS64--with delay echo set up.
I also tested it in realtime sequencer mode with the sequncer only
recording the notes played (not the arpeggiated notes). Again ARP/RIFF
MIDI OUT is set to transmit arps.
Here are the results based on the CHANNEL ASSIGN Dest[ination]
int --- arps go to external gear (as well as to internal synth)
ext --- only notes played go only to external gear (not to internal
synth)
both -- arps go to external gear (as well as to internal synth)
If you want arps to go only to external gear, set ROM Instrument on
all relevant layers to 000 :None. Personal preference: I renamed the
preset with the prefix Xrp for eXternal arp [Xrp:JUNOsis]. (The
capital letter makes the preset show up early in the navigator.)
Hope this helps.
--Steve
share
this
Re: Sending Arps to External Gear: How to make it happen
2007-01-07 by robotchas
No,no, I understand all that (but thanks for the explanation). I was
just pointing out that the synth and sequencer are separate entities:
 if you set a track to EXT the arpeggiator stops working, which
doesn't make any sense until you realize that the arps are in the
synth, not the sequencer, so an EXT part doesn't go through the
arpeggiator. The solution is as you describe.
> synth)
> Hope this helps.
> --Steve
> share
> this
2007-01-08 by steve_the_composer
Ooops. Sorry for implying the explantion was for you. I knew you know
how to do it. I hadn't sent arps external in years and forgot how to do
it myself. Prompted by your post, I reconstructed the steps and wrote
them down--just so they would be available here. (That's why I renamed
the topic; so that it would be found in a search using the words arp
and external.)
--Steve
2007-01-09 by robotchas
These intarnets are confusing.
It's a good explanation to have. You're a very helpful guy, Steve.
> and external.)
> --Steve
