CCs output on reset
2006-12-29 by soundcrafter
So I've been working on a track, and having this maddening glitch pop up on one of my other pieces of gear - Every time I reset playback (ie, press STOP 3 times) the patch I'm using on my AN200 goes all nutty on me and I have to reset it. So I change to a different patch & change back, and all is well - but it started to get on my nerves, so I decided to try and track it down. I fired up MIDIOx and did some testing. Turns out the XL7 is causing the problem! If you have Channel Assign for a track set to EXT or BOTH, a series of CCs are sent out on that channel when you reset the sequence: 07 7F 4 --- CC: Volume 0A 40 4 --- CC: PAN 4F 00 4 --- Control Change 50 02 4 --- Control Change I understand the first 2. Set CC#7 (Volume) to 127, and set CC#10 (Pan) to 64. But the next 2 correspond to CC#s 79 and 80 - and CC#80 controls LFO->VCA on the AN200! Unfortunately, there is no way to disable that on the AN200, other than disable ALL CCs, which I really don't want to do. So, my questions: Why does the XL send CC 79&80 on reset? What's the significance of those 2 CC #s? Is there any way to *not* send them? Or for that matter, is there a way to not send *any* CCs to outboard gear on reset? It seems to do more harm than good, at least for me... I checked the manual, browsed the menus on the XL, and checked the archives here, but I couldn't seem to find anything helpful. Sorry if this is old hat, but any help you can provide would be greatly appreciated! Thanks! DTK
