XL-7 analog output reference ?
2006-10-27 by Zsolt Szabó
Hello,
I have a problem with my setup.
I use RME Fireface 800 as audio interface with the XL-7.
So far the XL-7 was connected to the input 7+8 on the front
where gain is available for input signals. Gain was set to
low/normal and the XL-7 was easily overloading the converters
with Master Volume pot set at 3 o'clock. I was happy, everything
worked fine.
Now I changed the connections so the XL-7 is connected to line
level inputs (7+8) on the back of Fireface because the front connectors
are used for microphones.
Input reference level was/is set to -10 dBV on the Fireface.
Problem is that now my XL-7 with everything maxed out, full velocity,
full volume, max. master level, with all the 16 tracks playing can't
dirve enough the Fireface line level inputs. I can achieve a maximum
of -10 - 8 dB peak now.
In the XL-7 manual the Technical Specifications appendix specifies:
Max. Output Level: +4 dB
Output Impedance: 1000 Ohms
I would be curious about the max. output level reference.
There should be an "u" afeter the dB, not ?
Aaron, any thoughts on this ? My other synths easily achieve
clipping if i want to....
    Zsolt
p.s. Here is my mail to and the answer from RME technical support:
Zsolt Szabo schrieb:
> in the XL-7 manual the following technical info is published:
> How are these numbers affecting my setup ?
Well, the better question is: what does this number tell us? If this is
the correct original information than the answer is: nothing. There
needs to be a reference mentioned. Like with the rear input of the
Fireface. Setting it to -10 means 0 dBFS (full scale digital) is reached
at an analog input level of +4 dBu. Note the little u.
The impedance is no problem.
Regards
Matthias Carstens
RME
Re: [xl7] XL-7 analog output reference ?
2006-10-29 by Aaron Eppolito
Well, first off, I'd recommend using the S/PDIF out of the XL-7 into the S/PDIF in of the RME.  You will also get a low level that way, but normalized, it will be the best possible sound.  If you do have to use the analog outs, you can still normalize, but you be bringing up the noise as well.  The XL-7 has realtively quiet outputs not because the converters are bad, it's rather that there's a lot of headroom.  With 128 voices and some very peaky filters, it's pretty easy to get loud signals, and the XL-7 was designed not to clip.  The E4 Ultra series samplers used to have a headroom control to compensate for this, but unfortunately, the XL-7 series does not.
Note also that -8dB is not a bad level - that's still rather useable.
-Aaron
PS. Never, ever record the XL-7 with the volume knob anywhere other than full.  It is a digital volume control, meaning that as you turn it down, you're loosing bits.  The volume knob is only for convenience.  You should really do any volume reduction outside the box.
----- Original Message ----
Sent: Friday, October 27, 2006 2:38:01 PM
Subject: [xl7] XL-7 analog output reference ?
Hello,
worked fine.
    Zsolt
Regards
Matthias Carstens
RME
Yahoo! Groups Links
2006-10-29 by Zsolt Szabó
Hi Aaron,
thanks for the info.
Till now I used the XL-7 only on gainable inputs of the Fireface, so I
didn't mind this.
Unfortunately the SPDIF of the RME is occupied by the Lexicon MPX-1 which is
an older release and has only 18 Bit/20bit analog converters so I definitely
need
this on the SPDIF where 24 bits is available and I would rather avoid
conversions
here to make the effects as transparent as they may be.
I didn't recognize till now that the volume knob is acting in the digital
domain till now.
Thanks for the clarification.
Anyway the problem is manageable, it is just I had to be sure there's no
error in the
setup.
    Zsolt
To: <xl7@yahoogroups.com>
Sent: Sunday, October 29, 2006 4:41 AM
Subject: Re: [xl7] XL-7 analog output reference ?
-Aaron
Hello,
worked fine.
    Zsolt
Regards
Matthias Carstens
RME
Yahoo! Groups Links
Yahoo! Groups Links
Re: XL-7 analog output reference ?
2006-10-30 by robotchas
You probably already know about this, but don't forget that you have
up to 10dB of gain available in each preset layer as well (if it's not
already maxed).
Useful info about the digital volume control...
--- In xl7@yahoogroups.com, Zsolt Szabó <Zsolt.Szabo@...> wrote:
> Hi Aaron,
> didn't mind this.
which is
definitely
> need
> conversions
digital
> domain till now.
there's no
> error in the
> setup.
> Regards,
>     Zsolt
> From: "Aaron Eppolito" <synthesis77@...>
use the
noise as
converters are
and some
XL-7 was
headroom
does not.
> -Aaron
than
down,
should
> From: Zsolt Szabó <Zsolt.Szabo@...>
> To: xl7@yahoogroups.com
> Hello,
> worked fine.
> Thanks,
>     Zsolt
> Regards
> Matthias Carstens
> RME
Re: [xl7] Re: XL-7 analog output reference ?
2006-10-31 by Zsolt Szabó
Hello,
yes, I know I can gain each layer it just would be very frustrating
to do it for 512 presets. I'm full :))))
Anyway, -8 dB is not so worse, and as Aaron suggested I will
use gaining outside the box when needed through the FF 800,
probably only in the recording stage.
    Zsolt
Sent: Monday, October 30, 2006 8:42 PM
Subject: [xl7] Re: XL-7 analog output reference ?
already maxed).
--- In xl7@yahoogroups.com, Zsolt Szab\ufffd <Zsolt.Szabo@...> wrote:
> Hi Aaron,
> didn't mind this.
which is
definitely
> need
> conversions
digital
> domain till now.
there's no
> error in the
> setup.
> Regards,
>     Zsolt
use the
noise as
converters are
and some
XL-7 was
headroom
does not.
> -Aaron
than
down,
should
> From: Zsolt Szab\ufffd <Zsolt.Szabo@...>
> Hello,
> worked fine.
> Thanks,
>     Zsolt
> Regards
> Matthias Carstens
> RME
Yahoo! Groups Links
2006-10-31 by Szonyi Andras
> already maxed).
Yes that's true all layer can be gained up to 10dB,
but as I see, in that case you lose the velocity range.
And some of my presets' ADSR envelopes start to act strange.
(endless release time -using factory envelopes- and that kind of things)
a
2006-11-01 by robotchas
Yeah, doing it for all your presets would certainly suck! It can come
in handy if you need a specific patch to be a little hotter, and I've
gotten in the habit of making my patches as hot as I can without
clipping, so that I can turn down the volume as needed.
You're right that -8 isn't too bad - I do picture editing and we keep
everything under -6dB.
> Hello,
> Regards,
>     Zsolt
> From: "robotchas" <robotchas@...>
> already maxed).
> --- In xl7@...m, Zsolt Szabó <Zsolt.Szabo@> wrote:
> > Hi Aaron,
> > didn't mind this.
> which is
> definitely
> > need
> > conversions
> digital
> > domain till now.
> there's no
> > error in the
> > setup.
> > Regards,
> >     Zsolt
> > From: "Aaron Eppolito" <synthesis77@>
> the
> use the
> noise as
> converters are
> and some
> XL-7 was
> headroom
> does not.
> > -Aaron
> than
> down,
> should
> > From: Zsolt Szabó <Zsolt.Szabo@>
> > Hello,
> > worked fine.
connectors
> > Thanks,
> >     Zsolt
this is
reached
> > Regards
> > Matthias Carstens
> > RME
> > Yahoo! Groups Links
> > Yahoo! Groups Links
Hmm, if you route Vel< to Amp Volume you don't lose any velocity range
-  the XL7 subtracts (Vel-127) from the volume.
I haven't noticed the factory envelope problem, but I don't generally
use them. Interesting.
> a
