--- In xl7@yahoogroups.com, ed mann <gongworks@...> wrote:
> Greetings Everyone
> My XL7 has always worked flawlessly - but today, it
> will not power up. I have swapped chords and outlets
> and boxes etc checked the switch on the back -
> nothing. Does anyone have any experience of this type?
> I am correct in assuming there is probably a
> servicable fuse inside? Any input will be helpful
> before I take XL7 part.
> thanks very much!
> Ed Mann
> I have been had a problem like that but not the same: the engine
power up correctly but about 5 or 10 minutes after it run the engine
suddently "power down" ( if it's correct in english ). The problem
wasn't important. In fact, the cable of current has been inverted
with the cable of my table ( which doesn't appear so different but
the contact wasn't good so the unit power down ).
I have retrieved my old cable given with the unit and the problem was
solved.
Hope that a simple like that which appen to you. ( or may be the
fuse )
Bye
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
