MIDI ECHO can someone help
2006-01-28 by lifeistheformofenergy
I am not using
any external midi gear - I just want to stay in the XX7 and yet go
beyond it's parameters if so possible the thing is that there might
be some code embedded in the XX7 that actually prevents this sort of
thing from happening which is also what I am asking - what exactly gets
sent out and if rerouted what gets interpreted as actual effect during
imput - if other gear is used for effects - does it correctly interpret
the sysex or will it leave it only as note on or off ... how can a
rechannelized track be set up so that it acts as though it is
continues or realtime and still keeps changing the effect
information ...
Re: [xl7] MIDI ECHO can someone help
2006-01-28 by Bob S.
I don't think anyone answered you because they may not understand the question....Can you state just the question?  Do you want midi echo or do you want to prevent it?  If you want it, why when the XL7 has a digital echo built-in.  Real midi echo will reduce your polyphony if there is voice overlap and eats midi bandwidth.  You can create it but to make the loop, you will need a midi merge function....
Bob
Corona/Riverside, CA
  Sent: Friday, January 27, 2006 5:52 PM
  Subject: [xl7] MIDI ECHO can someone help
  I am not using
  information ...
  Yahoo! Groups Links
Re: MIDI ECHO can someone help
2006-01-28 by steve_the_composer
I will dissect your message into parts that make sense to me and
parts that make no sense to me.  I will also ask questions and make
comments to try to figure out what you are trying to do with your E-
Mu.
Other ways to try to understand your questions(s) include:
(1) State specifically what you are trying to do.
(2) Restate your question(s) using different words.
There are several people here who might be able to help you do what
you want, but--at least to me--it is unclear what you are trying to
do. I hope the following helps.
--- In xl7@yahoogroups.com, "lifeistheformofenergy"
<lifeistheformofenergy@y...> wrote:
> I am not using
I understand the first part (above.)
> and yet go
I am not sure what this (above) means.
Yes, there is "code" in the E-Mu.
This makes no sense to me. Prevents what sort of thing? If you
mean "prevents a user from going beyond the E-Mu's parameters," what
do you want to try to do that you cannot seem to do using the E-Mu's
parameters?
> sent out
This makes no sense to me since you are not sending anything out of
your E-Mu--except for audio (and I assume you are getting audio from
your E-Mu). Your question "what exactly gets sent out" would make
sense to me if you were sending midi data out to another device.  I
guess my question here is: Sent out from where TO where?
> and if rerouted
Are you talking about patch cords? If not, what?
Are you talking about the effects processor? If not what?
> during imput
Input FROM what INTO what?
Wait a second--you said you are not using external gear.  What is
your native language? Perhaps something is being lost in translation?
> - does it
What is "it?" The E-Mu or external gear that you are not using?
> correctly interpret the sysex
Most synth gear (including E-Mus) correctly interpret sysex.
> or will it
Again, is "it" the E-Mu or external gear that you are not using?
> leave it
HUH??????? Leave the sysex data?????????
Note on and note off data are not system exclusive data.  Are you
asking if sysex data will mess up note on/off data?
> ... how can a rechannelized track be set up
I understand the start of this question.
By "it" do you mean the rechannelized track? Does "it" in the second
half of the above mean the same thing as "it" in the first half?
> is continues
Not sure what you mean by this (above).
> or realtime
Not sure what you mean by this (above) either.
> and still keeps changing the effect information ...
Are you talking about the effects processor? If not, what do you
mean by "effect information?"
The patchcord method of simulating echo (using an lfo/sawtooth wave to
modulate the amp) won't reduce polyphony.  Its a trick I used a few
times on my first 8-voice synth! True, its not realo echo, but it can
be effective in simulating the effect.
Re: [xl7] Re: MIDI ECHO can someone help
2006-01-29 by Mibrilane
A valiant attempt to figure out what the heck he was asking, Steve. I
didn't even try to answer because I have no idea what the question
is. ;D
> Mu.
>> I am not using
>> and yet go
> parameters?
>> sent out
>> and if rerouted
>> during imput
>> - does it
>> or will it
>> leave it
>> is continues
>> or realtime
Mibrilane
2006-01-29 by Aaron Eppolito
My only attempt at deciphering the original  question is as follows.  I think he's asking if there's any way to  internally loop the MIDI output of a track back into the track,  possibly with some processing.  From a parameter or audio point of  view that sort of makes sense (i.e. feeding back parameter changes can  produce interesting effects and feeding back audio can yield filters,  flangers, and the like).  However, looping back MIDI isn't really  useful.
  Imagine a piano concert where the pianist asks the someone in the  audience to play every note he plays immediately after he plays it,  then asks that audience member to pick another audience member to play  every note the first one plays, and so on.  --  The pianist  plays the first C#.  Then an audience member comes up and plays it  again and nominates another member.  They play it and nominate a  third and so on.  Pretty soon, the whole audience is piled on top  of the piano, and we haven't even gotten past the first note in the  piece to be played...
  -Aaron
Mibrilane <mibrilane@...> wrote:  A valiant attempt to figure out what the heck he was asking, Steve. I
is. ;D
> Mu.
 wrote:
>> I am not using
>> and yet go
> parameters?
>> sent out
>> and if rerouted
>> during imput
>> - does it
>> or will it
>> leave it
>> is continues
>> or realtime
Mibrilane
Yahoo! Groups Links
 Yahoo! Autos. Looking for a sweet ride? Get pricing, reviews, & more on new and used cars.
2006-02-01 by lifeistheformofenergy
YES YOU DECIPHERED COREECTLY  - I am trying to find out how to change
parameters internally and I figured that looping it via midi track
rechannelization back into the track might have been the resolution
because the knob assignments only go so far ... and I thought that if
the data was changed and then rechannelized back onto the track again
it would allow for realtime adjustments that would keep adjusting the
parameters even though the knobs only go as far as they do ... so if
this is case is it possible to do this in realtime or is it possible
to do this all internally but not in realtime and how... ? btw thank
you so much for understanding like you do ! YOU ARE VERY SMART !
useful.
>   -Aaron
> Mibrilane <mibrilane@c...> wrote:  A valiant attempt to figure out
> is. ;D
make
E-
> > Mu.
what
to
>  wrote:
> >> I am not using
> >> and yet go
what
Mu's
> > parameters?
> >> sent out
of
from
I
> >> and if rerouted
> >> during imput
translation?
> >> - does it
> >> or will it
> >> leave it
second
> >> is continues
> >> or realtime
> > Yahoo! Groups Links
> Mibrilane
