sysEX parameters
sysEX parameters
2005-12-23 by lifeistheformofenergy
if a midi loop is created and then rechannelized to a specified track
and then that track is what you are adjusting using the programmed
knobs - how much would the information begin to go out of the
parameters of the knobs - or is there a break point where it just
stops adjusting the information - do you have to manually program
information outside of the knobs allowance if desired and then input
them to the xl and then sort of "ratchet" them where you want them or
how ... I ask because a lot of the times effects that can be used can
be put through processors twice or three times to get them the way I
need them and so it seems like creating an infinite midi loop would
work better ... please help ...
Re: [xl7] sysEX parameters
2005-12-23 by Bob S.
What do you mean by a 'midi loop"....as a real electrical midi loop will just lock up the midi signal path.  You change the midi channel along the way but you can not precess it through the same controls.  Do you really mean a midi "echo" such as one created by a midi processor to create a timed echo effect instead of creating the effect in the audio side ?
Bob
Corona/Riverside, CA
>From: lifeistheformofenergy <lifeistheformofenergy@...>
>Sent: Dec 23, 2005 4:56 PM
>To: xl7@yahoogroups.com
>Subject: [xl7] sysEX parameters
>Yahoo! Groups Links
Re: sysEX parameters
2005-12-25 by steve_the_composer
You have my curiosity. What is your setup? Specifically, what kind of
processing are you doing?
For example, are you talking about using multiple patchcords assigned
to single knobs entirely within the synth engine? Or, are you talking
about processing midi data externally and sending it back into the E-
Mu? (Or something else?)
I haven't done either of these but the idea sounds intriguing.
--Steve
2005-12-30 by lifeistheformofenergy
well thanks for your intellilectual interest - I thought the setup
that would work would be sending multiple patchcords or assigned by
preset or even just quick edit to knobs with in the internal synth
engine - I can't get it to work obvioiusly as mentioned but maybe it
is because of what bob said - basically the idea is to set up what I
thought would be a loop but bob says that won't work - so then after
this rouiting is configured it basically completes itself so that you
could possibly keep adjusting a parameter until you got it where you
needed it - so even if you turned the knob all the way once it went
through the "loop" or what I thought of calling the loop it would
complete the processing and go back through and be reprocessed (sort
of like a ratchet I suppose only more continual) ....
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
of
assigned
talking
E-
> --Steve
track
programmed
input
them or
can
way I
would
2005-12-31 by lifeistheformofenergy
well thank you for your intellectualism - you seem to know what it is
I am asking - which is good - ok so when you refer to an echo what
exactly does this mean ? it seems to me that you might be refering to
a given track outputing but also rechanellizing to another track and
then that track outputing to the original where as before I was only
talking about one initial track - is this the case ? I am not using
any external midi gear - I just want to stay in the XX7 and yet go
beyond it's parameters if so possible the thing is that there might
be some code embedded in the XX7 that actually prevents this sort of
thing from happening which is also what I am asking -
> Bob
> -----Original Message-----
> >From: lifeistheformofenergy <lifeistheformofenergy@y...>
track
input
or
can
I
would
> >work better ...> >
> >Yahoo! Groups Links
Going crazy recording CC data by extreme kbob turning (was: sysEX parameters)
2006-01-02 by steve_the_composer
I think by midi loop in your original post, you were referring to a
pattern that loops continuously within the E-mu itself, right? If so,
a loop could be created in a set of one or more sequencer tracks or
with an arpeggiated sequence of notes (the arpeggiator).
If you want to record CC [continuous controller] data into your
sequenced tracks using the knobs, you are limited by the amount og
your remaining memory.  If you "push the limits" of either memory or
performance with an overabundance of CC data from going crazy with the
knobs, you can thin the CC data using the THIN EVENT menu in the
pattern editing menu system.
I hope this come close to what you were trying to ask. If not, feel
free to clarify.
--Steve
