Volume knob -> power down problem, can't turn the unit back on??
2005-10-27 by tekno_freax
Hello everybody, I'm new to this group, I 've bought a second hand
XL-7 yesterday and have a very strange problem. Allready did a
search but couldn't find anything related to this (sorry if it has
been handeld before)
Here is my problem:
If I turn on the unit using the hard-wired switch on the back, the
unit turns on (most of the time) then, if I twist the volume knop
from full down to half-way, or sometimes just barely touch the
volume knob it goes into automatic power-down.
Then, when I franticly twist the volume knob, it usually goes out of
this power down, yesterday I was to late and it powered down.
Pushing the power knob on the front pannel doesn't do anything, and
after a lot of twisting the volume knob, and using the switch on the
back I got it to power up again. However the front pannel power on
button doesn't seem to do anything, and this morning I couldn't get
it to power on at all.
Does anybody know of this problem? Is the volume knob somehow
connected to the soft power switch? It's the strangest thing I have
ever seen on a piece of gear?!
Any help would be greatly appriciated, I would love to dive into
this machine but allready I am afraidof using it live, seeing it
could power down just by touching the volume knob...
Thanks in advance,
Ilja
Re: Volume knob -> power down problem, can't turn the unit back on??
2005-10-27 by malik
well the power button and volume knob share the same circuit board
with the headphone jack i think. so they must be having some sort of
bad relationship(do they share the same circuit board? havent looked
in a while) too bad i have no idea why it's doing that. im no
electrician.
good luck
> Here is my problem:
of
and
get
have
> Thanks in advance,
> Ilja
of
looked
> electrician.
> good luck
Hi Malik, thanks!
Thanks for a little insight, I'm no electrician either, but I also
noticed some humm on the headphone socket, and have read some
messages regarding this. Guess I'll be opening my unit tonight (and
crossing my fingers I don't mess it up more..)
If anayone else has any advice, I'll be happy to here it, I'll post
a message after tonight with my findings,.. or possible to vent some
frustation ;-)
Ilja
2005-10-28 by tekno_freax
--- In xl7@yahoogroups.com, "cimerian83" <cimerian83@y...> wrote:
> Hello to France !
> This solution to the humm noise is at :
http://fr.forums.audiofanzine.com/apprendre/mailing_forums/index,idto
pic
> ,151072,page,1.html#2511418
> Best regards !
Hello Cimerian83,
My knoweldge of the French language is almost non-existant, I'm from
the Netherlands, I did find an interesting link to a software
editor, so thanks for that.
Further, I found out yesterday that the soft on/off button only
works when the volume is between 0% and 50% full. Any higher and the
on-off button doens't work at all. Also it can power down by
twisting the volume knob from 100% position down to the 0%-50%
range. So there is definitly some strange connection between these
two parts... maybe some short-circuit between them.
Does anybody ever experianced this? I hope its a hardware problem,
at least that can be fixed!
RE: [xl7] Re: Volume knob -> power down problem, can't turn the unit back on??
2005-10-28 by BEAUFILS Adrien
As i 'm french user of this group i will try to explain the manip to solve you're problem:
In fact the volume knob and the jack headphone are "linked". Many user have problem with a "buzz" noise in the headphone. Maybe your problem have the same "source". It apppear that the jack headphone isn't corectly electricaly isolated from the box. So you will have to open your box and to throw off the jack headphone and the light (  the contact of the vomume knob too ). After the but is to isolate these components from the box ( all the components ). To do that you can simply buy an isolant varnish and to cover the pieces which are in contact with the box ( the part of the box too ). After doing this operation it seams that the problem of the "buzz" has been deseappear. Maybe it will work for your volume knob's problem.
Hope that you anderstand my translation.
> Hello to France !
pic
> Best regards !
Hello Cimerian83,
SPONSORED LINKS
Drum machines Electronic instrument Electronic drum machine Electronic music Electronic musical instrument Electronic instrument cases
YAHOO! GROUPS LINKS
    Visit your group "xl7" on the web.
 Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
 Téléchargez le ici !
Thank you very much!
Indeed it could be related, if there is some electrical "current-
leak" on that PCB, it sends out an OFF-signal if I turn the volume
knob! There is some logic in that, at least to me (no expert here)
I'll give it a try!
--- In xl7@yahoogroups.com, BEAUFILS Adrien <fatalojyxvsfacial@y...>
wrote:
> Hi,
> > Hello to France !
> pic
> > Best regards !
> Hello Cimerian83,
from
> Thanks,
> SPONSORED LINKS
cases
> YAHOO! GROUPS LINKS
Service.
Messenger
