What is this in Pattern Edit?
2005-10-23 by zerolatencyproductions
Okay I thought I was going to insert a stop or cut off the rest of the
bar.beat at the end of a pattern.  I went into the event edit screen
to add a bunch of mutes (I'm still looking for a better way of
stopping a song) when I came across C01 prog:0   m:off l:off.  Can
someone please tell me what I use this for?  It looks cool.  I hope
its useful.  Peace!
Brandon
Re: What is this in Pattern Edit?
2005-10-23 by gonzinigonz
Hi
Check this post out.. same thing differant problem
message No:- 17052
its all there..
Dont think you can insert mutes into a pattern?
Why do you need the bar to stop before the end of the bar?
cant you just create a new pattern and make sure its blank after that
point?
Gonz
--- In xl7@yahoogroups.com, "zerolatencyproductions"
screen
> its useful.  Peace!
> Brandon
2005-10-24 by steve_the_composer
C01 = midi channel 1
prog: 0 = change program/patch/preset to the program/patch/preset in
slot 0
m = msb = most significant bit for bank switching
l = lsb = least significant bit for bank switching
Since msb and lsb are both off in your example, the midi event tells
the synth to switch to preset/patch 0 in the current bank on midi
channel 1.
Try changing prog to another number and see what happens.
Now, select a preset in one of your roms, then press audition.  Do you
see an lsb and and msb number? If so, those numbers designate rom and
bank number.
If you want to insert a program change in the middle of a sequence,
you can add it using pattern edit if you know the rom number, the bank
number and the preset number.
Hope this makes sense.
As for ending a song, why not just press the stop button? Or why not
assign a foot pedal to stop the sequencer?
In pattern mode, patterns continue until you stop the sequencer.
However, in song mode, you can chain patterns together and have a STOP
at the end of the chain.
If you have an 8-bar pattern in the middle of your song that you want
to use at the end and have it stop after measure 6 beat 2 (for
example), why not just copy that pattern to another slot, change the
length to 6 measures, and delete all the notes and events after beat
2, and put a STOP even after it?
--Steve
> its useful.  Peace!
> Brandon
2005-10-24 by zerolatencyproductions
I don't think I can either.  I was going to copy a pattern to cut
off the ends at diffrent beats.  Then I realized it'd be easier to
insert the mutes in song mode where I want them.
It sounds better and it takes the end of the song somewhere.  If I
just repeated the same bar 4 times and abruptly ended it, it sounds
repeatative and cheap.
that point?
Yeah, but it would be much more work. I would have switch to pattern
mode, copy the pattern to another location, and then erase all the
notes after the cut off point on every track. Instead, in song mode,
I can step to the end of the song; and while in realtime record,
mute all the tracks when the time/beat comes.  Then I can go into
the song event edit mode, and place them exactly where I want them
with click point precision.
I'm fixing to look up that post you where talking about.  I gotta
figure out how to find it real quick.
Later, Brandon
--- In xl7@...m, "gonzinigonz" <gonzini@f...> wrote:
> Hi
> message No:- 17052
> its all there..
that
> point?
> Gonz
of
> the
> screen
Can
hope
> > its useful.  Peace!
> > Brandon
Thanks Steve.  That does make sense.  Now, I gotta figure out how to
use it. Can I insert it using just the command station or do I need
some kind of sysex editor?
Thanks Brandon,
P.S. Here are my answers to your questions.
not assign a foot pedal to stop the sequencer?
I want to have everything programed into the sequencer for several
different reasons.  Mainly, so if I'm not paying attention
everything will progress or stop the way its supposed to.  I just
answered another post that asked me a similar question.  See that
reply if you want for more reasons why.
the length to 6 measures, and delete all the notes and events after
beat 2, and put a STOP even after it?
It takes way too long. Again, see my reply to the other post.  After
experimenting all day with the subject, I found that its easier to
record the mutes in song mode when needed and place them in the song
event edit menu.
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
in
> slot 0
tells
> channel 1.
you
and
> bank number.
sequence,
bank
not
STOP
want
beat
> --Steve
of
> the
screen
Can
hope
> > its useful.  Peace!
> > Brandon
> to use it. Can I insert it using just the command station or do I
> need some kind of sysex editor?
No need for sysex on this one. The edit pattern menu system has two
editors: (1) edit notes and (2) edit events. In the event editor, you
can press repeat to insert a new event. One of the event types is the
program change event.
> After
> song event edit menu.
Sounds like a good solution, too.
--Steve
