? HOW LONG ?
2005-10-16 by lifeistheformofenergy
? How long should an xl 7 be on before one should wonder or worry about it getting damaged ?
2005-10-16 by Bob S.
What voltage are you running it at and what is the general temperature environment of the area ? Bob -----Original Message----- From: lifeistheformofenergy <lifeistheformofenergy@...> Sent: Oct 15, 2005 8:20 PM To: xl7@yahoogroups.com Subject: [xl7] ? HOW LONG ? ? How long should an xl 7 be on before one should wonder or worry about it getting damaged ? Yahoo! Groups Links
2005-10-16 by Mibrilane
On Oct 15, 2005, at 8:20 PM, lifeistheformofenergy wrote: > ? How long should an xl 7 be on before one should wonder or worry > about > it getting damaged ? In my experience, computers with no moving parts (i.e. no hard drives, fans, etc.) can be on indefinitely and should not be damaged by being on. The XL-7 is essentially a computer, so I would imagine it is not going to be damaged by being on for extended periods. Of course, the easy solution to this worry is to shut it off when you're not using it. ;D --- Mibrilane [Non-text portions of this message have been removed]
I asked the voltage question because the group has found the XX-7s run much hotter on 220/240 volts and have a higher incidence of failure. The final recommendation was to use a step down transformer and operate the units at 120V. Bob Corona/Riverside, CA -----Original Message----- From: lifeistheformofenergy <lifeistheformofenergy@...> Sent: Oct 15, 2005 8:20 PM To: xl7@yahoogroups.com Subject: [xl7] ? HOW LONG ? ? How long should an xl 7 be on before one should wonder or worry about it getting damaged ? Yahoo! Groups Links
GOOD QUESTION buddy - I will have you know that here in America we run our frequency at 60 Hrz with 120 V (generally) (sometimes 240 V in big appliances, usually with those big 3 prong plugs) - UK it is 100 V with 50 HRz - --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > > I asked the voltage question because the group has found the XX-7s run much hotter on 220/240 volts and have a higher incidence of failure. The final recommendation was to use a step down transformer and operate the units at 120V. > > Bob > Corona/Riverside, CA > > > -----Original Message----- > From: lifeistheformofenergy <lifeistheformofenergy@y...> > Sent: Oct 15, 2005 8:20 PM > To: xl7@yahoogroups.com > Subject: [xl7] ? HOW LONG ? > > ? How long should an xl 7 be on before one should wonder or worry about > it getting damaged ? > > > > > > > > Yahoo! Groups Links >
even with the step down convertor how long - I ask because when I get into a session - I have to get into a session - I get serious about what I do because I don't have all the time in the world to do what I do - so when I do stuff it is in large brackets of time and I don't want there to be problems that can't be fixed - nobody deserves that either so I thought this was a good question ... --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > > I asked the voltage question because the group has found the XX-7s run much hotter on 220/240 volts and have a higher incidence of failure. The final recommendation was to use a step down transformer and operate the units at 120V. > > Bob > Corona/Riverside, CA > > > -----Original Message----- > From: lifeistheformofenergy <lifeistheformofenergy@y...> > Sent: Oct 15, 2005 8:20 PM > To: xl7@yahoogroups.com > Subject: [xl7] ? HOW LONG ? > > ? How long should an xl 7 be on before one should wonder or worry about > it getting damaged ? > > > > > > > > Yahoo! Groups Links >
Well, I'm not very good at deciphering indirect answers but if you are in the US, that is, 120V, then there is no problem with leaving the command station on indefinitely, I have left it on for months at a time without a problem and went picked up where I left off. However, I keep all my computer based synth gear on UPS power, because you never know when power can drop and lose or corrupt your work...... Bob Corona/Riverside, CA -----Original Message----- From: lifeistheformofenergy <lifeistheformofenergy@...> Sent: Oct 15, 2005 9:55 PM To: xl7@yahoogroups.com Subject: [xl7] Re: ? HOW LONG ? GOOD QUESTION buddy - I will have you know that here in America we run our frequency at 60 Hrz with 120 V (generally) (sometimes 240 V in big appliances, usually with those big 3 prong plugs) - UK it is 100 V with 50 HRz - --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > > I asked the voltage question because the group has found the XX-7s run much hotter on 220/240 volts and have a higher incidence of failure. The final recommendation was to use a step down transformer and operate the units at 120V. > > Bob > Corona/Riverside, CA > > > -----Original Message----- > From: lifeistheformofenergy <lifeistheformofenergy@y...> > Sent: Oct 15, 2005 8:20 PM > To: xl7@yahoogroups.com > Subject: [xl7] ? HOW LONG ? > > ? How long should an xl 7 be on before one should wonder or worry about > it getting damaged ? > > > > > > > > Yahoo! Groups Links > Yahoo! Groups Links
2005-10-16 by bbbigup bbbigup
Yes Bob S., you're right, some people who work under 220/240 had some problems.With the stanby because the power supply stay on, and it be very hot.And with a little problem on the electric line the power supply break, sometime with the motherboard.Me i always put off my xl-7 with the switch on the rear, never stand by.
"Bob S." <tttsystems@...> a écrit :Well, I'm not very good at deciphering indirect answers but if you are in the US, that is, 120V, then there is no problem with leaving the command station on indefinitely, I have left it on for months at a time without a problem and went picked up where I left off. However, I keep all my computer based synth gear on UPS power, because you never know when power can drop and lose or corrupt your work......
Bob
100 V with 50 HRz -
> Bob
about
Yahoo! Groups Links
YAHOO! GROUPS LINKS
Visit your group "xl7" on the web.
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez le ici !
[Non-text portions of this message have been removed]2005-10-16 by lifeistheformofenergy
well I personally think it is a better idea to shut it off with the switch becuase that way there is no discrepincy about voltage being wasted from the outlet because the actual circuit is "open" - but thats me trying to save the world on little kilowatt at a time - as far as leaving the device on for months or even days - I don't have that much time at one time besides it is easy to save things along the way - then stop - do what is necessary and then continue - I just thought for some reason that 8 hours might be getting to be long for it considering it doesn't have a fan ... yes I realize emu had good and intuitive intentions with the XX 7 - but honestly when things get hot even to certian seemingly low temperatures memory in general is volitile and thus suseptable to what is known commonly/collectively as "frying" - I happen to be a good parent of my device - I don't want my device to start smokin - its bad for the health you know ... --- In xl7@yahoogroups.com, bbbigup bbbigup <bbbigup@y...> wrote: > > Yes Bob S., you're right, some people who work under 220/240 had some problems.With the stanby because the power supply stay on, and it be very hot.And with a little problem on the electric line the power supply break, sometime with the motherboard.Me i always put off my xl-7 with the switch on the rear, never stand by. > > "Bob S." <tttsystems@e...> a écrit :Well, I'm not very good at deciphering indirect answers but if you are in the US, that is, 120V, then there is no problem with leaving the command station on indefinitely, I have left it on for months at a time without a problem and went picked up where I left off. However, I keep all my computer based synth gear on UPS power, because you never know when power can drop and lose or corrupt your work...... > > Bob > Corona/Riverside, CA > > > > -----Original Message----- > From: lifeistheformofenergy <lifeistheformofenergy@y...> > Sent: Oct 15, 2005 9:55 PM > To: xl7@yahoogroups.com > Subject: [xl7] Re: ? HOW LONG ? > > GOOD QUESTION buddy - I will have you know that here in America we > run our frequency at 60 Hrz with 120 V (generally) (sometimes 240 V > in big appliances, usually with those big 3 prong plugs) - UK it is > 100 V with 50 HRz - > > > > > > --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > > > > I asked the voltage question because the group has found the XX- 7s > run much hotter on 220/240 volts and have a higher incidence of > failure. The final recommendation was to use a step down transformer > and operate the units at 120V. > > > > Bob > > Corona/Riverside, CA > > > > > > -----Original Message----- > > From: lifeistheformofenergy <lifeistheformofenergy@y...> > > Sent: Oct 15, 2005 8:20 PM > > To: xl7@yahoogroups.com > > Subject: [xl7] ? HOW LONG ? > > > > ? How long should an xl 7 be on before one should wonder or worry > about > > it getting damaged ? > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "xl7" on the web. > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger > Téléchargez le ici ! > > [Non-text portions of this message have been removed] >
2005-10-16 by gonzinigonz
Heat is a killer with electronics and it seems that the switch mode in these command stations is the weak part. I run mine on 110v (in the uk with 240v) which drops the internal temperature down alot. As for leaving it on for exstended periods of time it shouldnt cause any damage. Most DSP's (older generation..) will get upto around 60ºC and that seems to be within spec. Thats getting too hot to touch for more than a second! Only probelm really is caps drying out in the power supply, but that will happen eventually anyway. I never leave any appliances on anyway, its saves on the bills and the whole planets being sucked dry as it is ;o) Gonz --- In xl7@yahoogroups.com, "lifeistheformofenergy" <lifeistheformofenergy@y...> wrote: > > well I personally think it is a better idea to shut it off with the > switch becuase that way there is no discrepincy about voltage being > wasted from the outlet because the actual circuit is "open" - but > thats me trying to save the world on little kilowatt at a time - as > far as leaving the device on for months or even days - I don't have > that much time at one time besides it is easy to save things along > the way - then stop - do what is necessary and then continue - I just > thought for some reason that 8 hours might be getting to be long for > it considering it doesn't have a fan ... yes I realize emu had good > and intuitive intentions with the XX 7 - but honestly when things get > hot even to certian seemingly low temperatures memory in general is > volitile and thus suseptable to what is known commonly/collectively > as "frying" - I happen to be a good parent of my device - I don't > want my device to start smokin - its bad for the health you know ... > > > > > > > > > --- In xl7@yahoogroups.com, bbbigup bbbigup <bbbigup@y...> wrote: > > > > Yes Bob S., you're right, some people who work under 220/240 had > some problems.With the stanby because the power supply stay on, and > it be very hot.And with a little problem on the electric line the > power supply break, sometime with the motherboard.Me i always put off > my xl-7 with the switch on the rear, never stand by. > > > > "Bob S." <tttsystems@e...> a écrit :Well, I'm not very good at > deciphering indirect answers but if you are in the US, that is, 120V, > then there is no problem with leaving the command station on > indefinitely, I have left it on for months at a time without a > problem and went picked up where I left off. However, I keep all my > computer based synth gear on UPS power, because you never know when > power can drop and lose or corrupt your work...... > > > > Bob > > Corona/Riverside, CA > > > > > > > > -----Original Message----- > > From: lifeistheformofenergy <lifeistheformofenergy@y...> > > Sent: Oct 15, 2005 9:55 PM > > To: xl7@yahoogroups.com > > Subject: [xl7] Re: ? HOW LONG ? > > > > GOOD QUESTION buddy - I will have you know that here in America we > > run our frequency at 60 Hrz with 120 V (generally) (sometimes 240 V > > in big appliances, usually with those big 3 prong plugs) - UK it is > > 100 V with 50 HRz - > > > > > > > > > > > > --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > > > > > > I asked the voltage question because the group has found the XX- > 7s > > run much hotter on 220/240 volts and have a higher incidence of > > failure. The final recommendation was to use a step down > transformer > > and operate the units at 120V. > > > > > > Bob > > > Corona/Riverside, CA > > > > > > > > > -----Original Message----- > > > From: lifeistheformofenergy <lifeistheformofenergy@y...> > > > Sent: Oct 15, 2005 8:20 PM > > > To: xl7@yahoogroups.com > > > Subject: [xl7] ? HOW LONG ? > > > > > > ? How long should an xl 7 be on before one should wonder or worry > > about > > > it getting damaged ? > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > YAHOO! GROUPS LINKS > > > > > > Visit your group "xl7" on the web. > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > --------------------------------- > > > > > > > > > > > > --------------------------------- > > Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! > Messenger > > Téléchargez le ici ! > > > > [Non-text portions of this message have been removed] > > >
