presets
presets
2005-10-14 by lifeistheformofenergy
is it possible to have multiple patterns applied to the same preset or
does the preset have to be copied to a different location ?
RE: [xl7] presets
2005-10-14 by bbbigup bbbigup
Yes it is possible. If you want exactly the same sound for all the pattern.
lifeistheformofenergy <lifeistheformofenergy@...> a écrit :is it possible to have multiple patterns applied to the same preset or
SPONSORED LINKS
Drum machines Electronic instrument Electronic drum machine Electronic music Electronic musical instrument Electronic instrument cases
YAHOO! GROUPS LINKS
    Visit your group "xl7" on the web.
 Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
 Téléchargez le ici !
Pointers (was Re: presets)
2005-10-15 by steve_the_composer
One thing that might help people get a handle on their E-Mu is the
concept of POINTERS. It is a concept in computing, and remember--
electronic music gear are really just specialized computers
One of the main functions of computers is to point.
You the user have control over some pointers the E-Mu uses. You do not
have control over other pointers. For example, consider the sound
ROMs. They have digitized sound >>samples<<, but you do not have
access to these directly. However, samples and multisamples are
organized by the e-mu architecture to have pointers to >>ROM
instruments<< in the EDIT PRESET functionality.
When edit a preset and change a preset's instruments on layers 1->4,
you are setting pointers to the ROMs table of contents (so to speak)
which points to the digitized sound samples.
Then, when you save the preset, let's call it My Sax 1.0, to User
memory slot 025 in bank 3, you are setting a pointer to the cluster of
parameters called a preset.
NOW:
When you create a sequence (pattern or song) you set pointers (in
effect) to a table of contents which point to the preset parameters.
If on Track 2 I want to use My Sax 1.0 on channel 5, I set a pointer
that says to the sequencer: "Hey, on track 2, any notes played on
channel 5 get played with the sound I am calling My Sax 1.0."
SO:
If you want, you can have 5 different channels on track 1, 3 different
channels on track 7, and 16 different channels on track 9 all pointing
to My Sax 1.0.
I hope the explanation of pointers helps. Once you figure out which
ones you have control over and where they can point to, I think you
will have a great deal of mastery over your gear.
--Steve
> or does the preset have to be copied to a different location ?
Re: presets
2005-10-16 by lifeistheformofenergy
Can they be at the same time though - if so - how many ?
pattern.
> lifeistheformofenergy <lifeistheformofenergy@y...> a écrit :is it
> SPONSORED LINKS
cases
> YAHOO! GROUPS LINKS
Service.
Messenger
Re: [xl7] Re: presets
2005-10-16 by Bob S.
Until you run out of polyphony, based on the polyphony usage rules for the command station (in the manual).  For example, a chorused voice uses twice the polyphony of a non-chorused voice, etc, etc., up to the polyphony count of 128 for the XX-7......
Some of our old posts delve specifically into effective polyphony.....
Bob
Corona/Riverside, CA
From: lifeistheformofenergy <lifeistheformofenergy@...>
Sent: Oct 15, 2005 8:19 PM
Subject: [xl7] Re: presets
pattern.
> lifeistheformofenergy <lifeistheformofenergy@y...> a \ufffdcrit :is it
> SPONSORED LINKS
cases
> YAHOO! GROUPS LINKS
Service.
Messenger
>  T\ufffdl\ufffdchargez le ici !
Yahoo! Groups Links
2005-10-16 by Mibrilane
Technically every sequencer track can have the same preset on it.
However, one would have to start asking oneself:  why the heck do I
have the same preset on every sequencer track? ;D
Mibrilane
presets
thanks - funny answer - I suppose I really should have specified :
how many before problems are encountered or that the XX 7 gets slowed
down (if so) ... we wouldn't want over loads now would we ... we need
to make it back to the mother load ship - you just encountered an
alien - welcome back to space - the truth is out there - doo doo doo
doo duh do doo dooo ... thanks for tuning in to my brief version of X
files ... tune in for some more techno -
I
> Mibrilane
