Index last updated: 2026-04-03 18:22 UTC
lost operating system
2005-10-11 by bagoes kardhono
anybody can help me about my xl-7?
at the beginning I turn on this machine and then show "searching for
OS...." please give me some advise, thank's bro
Re: lost operating system
--- In xl7@yahoogroups.com, "bagoes kardhono" <donnymstation@y...>
I'm try to fix this machine with upgrade to command200.dli but
show "error......" what I should todo?
RE: [xl7] Re: lost operating system
2005-10-11 by bbbigup bbbigup
Have you try to load a different os?
In France some persons have the same pb after the power supply die.
If your xl-7 dont want to load an OS, it can be that the xl-7 bios is corrupt.
I dont know exactly how to fix this, but i think you can change or re-program the eprom  with the xl7 bios.It's somethonk hard to find.
Is there anybody to confirm this...
Good luck.
YAHOO! GROUPS LINKS
    Visit your group "xl7" on the web.
 Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
 Téléchargez le ici !
2005-10-12 by bagoes kardhono
is corrupt.
> Good luck.
for
thank's bro, i have tried with different way, first I load
commandprep10.dli then show "ERROR Downloading, MIDI: Time Out" other
time it work and show "Replace Bootloader?" enter "flash erased"
and "Flashprep V10 successful ***Please Reboot*** that what i do
after now and then i load command131.dli, show up "ERROR Downloading
MIDI: Wrong Length" or after download complete show "error code=001,
fatal: bus address error" I almost hopeless with this machine....
2005-10-12 by bob_at_work_2000
Sounds like midi interface problems.....what interface are you using
and how are you connected to the XL-7 ?
Bob
Corona/Riverside, CA
2005-10-12 by bbbigup bbbigup
"thank's bro, i have tried with different way, first I load
fatal: bus address error" I almost hopeless with this machine...."
So you can load succesfully the first os , but with a little bit probleme.
Is the xl-7 work fine with the 1.0 os?
What kind of pc do you use, maybe you have an usb problem , or cable problem.
Have you also try to remove and install e-loader?Is it the e-loader 1.1?
Jym.
is corrupt.
> Good luck.
for
YAHOO! GROUPS LINKS
bob_at_work_2000 <tttsystems@...> a écrit :
"Sounds like midi interface problems.....what interface are you using
Bob
Corona/Riverside, CA"
Yes i dont remember if the load operation work with usb...I supposed i have done this with the midi cable sold with the xl-7.
If you use this cable or an other midi cable it can be a cable problem or sound card problem.
I guess that if you can load the first os, you can load all other os.I ll be better that no error message appear when doing the operation.
Jym.
SPONSORED LINKS
Drum machines Electronic instrument Electronic drum machine Electronic music Electronic musical instrument Electronic instrument cases
YAHOO! GROUPS LINKS
2005-10-13 by bagoes kardhono
Hi Bob, i'm using computer desktop, win xp, aadvark 24/96 for midi
converter and routing via midi in and out, because if I connect via usb
win xp could not recognize the device. Is there any solution?
Bagoes
Jakarta/Indonesia
> Bob
