"Oh, you've got to have Daaaaaaa taaa." (sung to the tune of "Friends"
written by Buzzy Linhart--"You've got to have friends" as performed by
Bette Midler)
Meaning: before or after you change the channel assignments, but
before your save the pattern, put some benign data on the track. For
example: any cc data [set volume at 127, for example].
If there is no data on the track, the save routines will reset the
track to default settings.
[I will try to find the discussion of this in the archives.]
Hope this helps.
--- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote:
> hi
> im trying to save channel assignments in the pattern assignment menu.
> ive saved the mutisetup the patter and the preset but if i turn the
mp-
> 7 on or off the channel assigments go back to the default settings.
