what should i do? sell mp-7 and get a new one? or get it serviced?
Re: [xl7] what should i do? sell mp-7 and get a new one? or get it serviced?
2005-08-12 by moose
On 12/8/05 4:28 PM, "malik" wrote:
> i have a problem with my right output on the main channel and am
> thinking i should probably just sell it on ebay and get another.
> should i? i know it will probably cost a fortune to get serviced!!!
the emu service centre down in florida are very good - i dealt with richard
bruyn @ epr electronics when my e4xt ultra had a bad chip & he was very
professional & efficient.  and my machine now works perfectly!
if it has just a bad socket then they are easy to change and i doubt it'll
cost too much **unless** it has a major problem on the circuit board itself.
but be warned that the machines are around $300 used, so if the quote to fix
climbs too high then consider selling.
email :
  moose@...
music sites :
  http://www.pigpendigital.com
  http://www.alaskahighway.com
  http://www.mishikawa.com
Re: what should i do? sell mp-7 and get a new one? or get it serviced?
2005-08-13 by malik
i was affraid of that!
i have a book that teaches me how to solder and i have radio shack
is up the street and they have the mounted stereo plug  just like
the one inside my mp7 i might try fixing it but im skurd....
serviced!!!
with richard
very
doubt it'll
board itself.
quote to fix
> email :
>   moose@p...
> music sites :
Re: [xl7] Re: what should i do? sell mp-7 and get a new one? or get it serviced?
2005-08-13 by moose
often this kind of problem in inside the female jack itself, where the
contacts physically touch the 1/4" plug.  i had the same problem on an old
yamaha rx5 drum machine years ago. it got so bad that the connector actually
broke off!
anyways, have a look inside the unit & if its a sealed female casing then
look at any identifying number and head, as you say, to your local
RadioShack.  their range has shrunk to mobile phones & the odd plug, but
hopefully you'll find something...  if not there are a number of really good
online stores, and if you don't feel up to soldering then check out your
local TV Repair centre - usually these guys are very good & don't charge too
much.  peace of mind & all that...
btw my *new* XL7 can be seen here <http://analoguehaven.com/used>
email :
  moose@...
music sites :
2005-08-13 by malik
nice setup you have there and an interesting website. nice
photography!!
i had opened her up. the mo phat rom was in slot 3 so i put it in
slot zero unscrewed everything from the bottom board and connectors
in the rear pannel looked on both the top and bottom of the board
and all connections looked crisp. so i took some q tips sticks and
whateever else i could find and started poing inside of the main.
then. then i started to blow in int. screwed everything back up, and
now it works!!!
thanks man!! i guess when the shit hit's the fan i can actualy
accomplish things on my own. (too bad the shit has to hit the fan
first)
shack
on an old
connector actually
> broke off!
casing then
plug, but
really good
out your
charge too
> email :
>   moose@p...
> music sites :
2005-08-13 by moose
> photography!!
'analogue haven' is our new store near LA, based in an old art gallery,
where we have some weird & esoteric stuff.  my studio is **slightly**
smaller <http://alaskahighway.com/studio> but works exactly the way i need
it to, with most of the gear to my left in the skb racks.
the cool photo's on the AH site are mostly mine, though we have a load of
stock photos from manufacturers on the site which will be replaced over the
coming few months...
> now it works!!!
well, sometimes machines just need a clean, as well as unplugging, blowing &
replugging all the connector cables.  as long as you don't lose track of
which plug went where you should be ok - taking digital pictures as you go
is always a good route.
often these contacts just need a bit of alcohol on 'em to clean off the
crud.
also, and this is quite a delicate operation, getting a very very small
screwdriver and moving the contacts inside the female adapters so they
aren't so flush to the sides often helps too.
> first)
yay...  another happy customer, err...  i mean abuser!  glad to have saved
you some money!
right, i'm off home soon & plan on getting out the XL7 for a play...
email :
  moose@...
music sites :
2005-08-13 by moose
> photography!!
> now it works!!!
crud.
> first)
you some money!
email :
  moose@...
music sites :
