programmable knobs
programmable knobs
2005-06-01 by malik
hi there.
when you set the programmable knobs in the controler menu for external
controlling i know that you can only set controll for 16 knobs but is
there  a way like say, switching presets that i can have a totaly new
set of controllers. or is my only way of getting around this through
multisetups?
Re: programmable knobs
2005-06-01 by malik
cool just got one of my midi books back from my brother so i can
learn how to use bank messages(after all these years i finaly have a
reason to) but i wont be able to try till i get back home. didnt pay
the internet bill this month.....
thanks
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
wrote:
> Double check the manual, but I think programmable controller
settings
> are saved with Mulisetups. Multis can be called with bank
> switch/program change commands.  That sounds like what you are
asking
> to do.
> Hope this helps.
> --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote:
> > hi there.
> external
but
> is
totaly
> new
through
> > multisetups?
2005-06-01 by steve_the_composer
Its rather simple. You don't need a midi manual. You send two
numbers to determine the bank [Bank Select MSB and Bank Select LSB]
followed by a program change. Bank Select controls are CCs.  (Look
in the Appendix to your manual.Bank Select MSB is CC#0; Bank Select
LSB is CC#32.
BUT:
The folks at E-Mu made it easy for you. You can set it up on ONE
PAGE in the E-Mu event editor.
1. Go to the event editor, insert a prog event.
2. That's it!!!
m = msb = most significant byte = E-Mu ROM ID
l = lsb = least significant byte = E-Mu ROM Bank
prog = program change = E-Mu Patch Number.
msb/ROM ID can be gotten by pressing audition.
To switch multisetups, use msb = 80, lsb = 0. (Its in the manual
under Restoring multisetups.)
Hope this helps.
a
pay
> thanks
> settings
> asking
> > to do.
> > Hope this helps.
> > > hi there.
> > external
> but
> > is
> totaly
> > new
> through
> > > multisetups?
2005-06-02 by malik
cool thanks i havent tried yet. i am trying to make a speacil midi
module for live performances... and thats not really goin well at
the moment. i will try tonight. but when i change multisetups will
playback be haulted?
LSB]
Select
> LSB is CC#32.
> BUT:
> 2. That's it!!!
> Hope this helps.
have
> a
> pay
> > thanks
> > settings
> > asking
> > > to do.
> > > Hope this helps.
> > > > hi there.
for
> > > external
knobs
> > but
> > > is
> > totaly
> > > new
> > through
> > > > multisetups?
2005-06-02 by steve_the_composer
Good question.  I don't recall if you miss a beat.  Most likely you
will have some noticeable change if you switch a multi during
playback. Multis include preset data on all channels, so, you will
be change those.
IMPORTANT: Make sure you have your current multisetup stored, so you
can restore it.
If you are not careful, or you don't know what you are doing when
you switch multisetups you could have unhappy results.  For example,
if you switch to a multi that doesn't receive midi, you won't be
able to do anything after that change.  Also, if you change from a
multi that that sends clock to a multi that doesn't send clock, your
outgoing clock will no longer be sent.
POSSIBLE ALTERNATE ROUTE: I haven't tried this, but just try
changing the controller assignments via sysex parameter editing. See
Master MIDI Parameters in the sysex manual).
> LSB]
(Look
> Select
> > LSB is CC#32.
> > BUT:
> > 2. That's it!!!
> > Hope this helps.
can
> have
> > a
didnt
> > pay
> > > thanks
mail@p...>
> > > settings
are
> > > asking
> > > > to do.
> > > > Hope this helps.
wrote:
> > > > > hi there.
> for
> > > > external
> knobs
> > > but
> > > > is
> > > totaly
> > > > new
this
> > > through
> > > > > multisetups?
2005-06-02 by malik
yeah i'll have to try that alternative!! havent looked in the manual
yet but maybe i could save midiox presets or something?
you
> be change those.
you
> can restore it.
example,
your
See
midi
at
will
> > LSB]
> (Look
> > Select
> > > LSB is CC#32.
> > > BUT:
ONE
> > > 2. That's it!!!
manual
> > > Hope this helps.
> can
finaly
> > have
> > > a
> didnt
> > > pay
> > > > thanks
> mail@p...>
controller
> > > > settings
> are
> > > > asking
> > > > > to do.
> > > > > Hope this helps.
> wrote:
> > > > > > hi there.
menu
> > for
> > > > > external
> > knobs
> > > > but
> > > > > is
a
> > > > totaly
> > > > > new
> this
> > > > through
> > > > > > multisetups?
I just did a simple test. You can set up your controllers (MidiA,
MidiB, MidiC, etc.) in a single sysex chain and embed them in a pattern
See the sysex manual for the details of Parameter Edit/Request if you
don't already know how to do that.
Here's the test string I used:
F0 18 0F 00 55 01 02 07 03 19 00 08 03 19 00 09 03 19
00 0A 03 19 00 0B 03 19 00 F7
Parameter 07 03 is MIDI_A_CONTROL.
I set that to 19 00 [controller 25 in decimal).
I also did the same for MIDI_B_CONTROL (08 03) --> MIDI_E_CONTROL (0B
03).
Using SOnar I placed the sysex bank at measure 1 beat 1 and another
sysex bank to change MidiA --> MidiE to Coontroller 16 (decimal) at
measure 1 beat 3. I then saved the "song" as a *.mid file (format 0, I
think), and loaded it into the P2500 with e-loader.
Since the CC 25 sysex was at tick 0, when I loaded the "song" and when
I reset it by pressing stop twice, MidiA --> MidiE changed to CC 25.
At beat 3, they changed to CC 16 and stayed there.
I didn't test it with note data, but my guess is that the sysex
strings are so short, they will not cause a glitch during playback
with note data.
I will upload the test sequence.  If you try it, save your multi first-
-or at leaste write down your controller settings so you can change it
back.
--Steve
> yet  . . . .
2005-06-08 by malik
cool !! sorry for the late reply but im at a public library my
internet is still down. i'm going to print this out and do it when i
get home. thanks a bunch steve youre a life saver.
> 03).
> with note data.
> back.
> --Steve
> > yet  . . . .
2005-06-19 by malik
steve i have takena look at this and have been trying to figure out a
way to do it over the past week or so. even openbed a bok with a
small section on sysex but i couldnt figure it out. and i diidnt
understand what the emu sysex manual was trying to tell me. is there
a website orsomething that can explain it to a complete idiot? :)
pattern
you
(0B
> > 03).
another
at
0, I
when
25.
playback
> > with note data.
first-
change it
> > back.
> > --Steve
manual
> > > yet  . . . .
2005-06-20 by steve_the_composer
There are websites that cover sysex. There is one that I stumbled on
that I thought was pretty good in terms of explaining it to novices. I
will have to look to see if I still have the links.
At the present, I do not have the time to write up my own explanation.
However, I know sysex has been discussed here, in the P2K group, and
in the P2500 group.  You might want to search the archives for "sysex."
Do you have a computer hooked up to your E-Mu? If so, do you have
sequencer software that can send and receive sysex?
Finally, did you save your current mutisetup and then try the file I
created--crtl-syx0.mid? If so, did it successfully change your
controllers as I decribed?
--Steve
a
there
Sysex tutorials/info/websites
2005-06-21 by steve_the_composer
The following site might be helpful. It has a simple navigation
frame. Click on system exclusive. I think the explanations on this
site are really geared toward novices, but impart real understanding.
http://www.borg.com/~jglatt/tech/midispec.htm
If you can handle charts as an explanatory mechanism, the following
site may be helpful:
http://www.hinton.demon.co.uk/midi/midicode.html#msex
Good luck.
--Steve
on
novices. I
[snip]
out
> a
> there
2005-06-22 by malik
i tried downloading a couple times but i wasnt abloe to get it. maybe
it's cause im using firefox?
> --Steve
> a
> there
Re: Sysex tutorials/info/websites
2005-06-22 by malik
hehe thats all i understand i think my brain is scared to send it. i'm
not sure how to send it.
> The following messages might also be helpful to understand midi.
> http://launch.groups.yahoo.com/group/xl7/message/11438
> http://launch.groups.yahoo.com/group/xl7/message/11439
> I know I did an anatomy of a E-Mu sysex command somewhere, but I
> haven' found it yet.  It went something like this:
> Open Remote Control Session:
> F0 18 0F 00 55 40 10 F7
> F0 = "Hey! Listen up everyone! There's system exclusive data coming."
> 18 = "It's just for gear manufactured by E-Mu"
> 0F = "It's specifically for E-Mu's Proteus Family"
> 00 = "And I'm only talkin' to those devices who have their sysex ID
> set to 00."
> etc.
> Hope this helps
2005-09-02 by malik
i think i'm finaly getting it.
i have a trigger button set to channel 14b on the mp-7  and i want
to use that button to send a message to midiox's translation map.
so i have the trnslation map open and im defining a mapping.
input channel 14 the mesage type is note on. note is E4 so i'm
assumming that that's not 41 so i have the min and max note number
to 41. i have velocity set to -1 on min and max wich in midiox means
any.
i set output channel to 1 since im not exactly sure what channel to
put it to yet but that's no big concern for me right now.
i know this is a sysex message but the book tells me to "select
c00=80, cc32=00,(dec) then send a Program Change command
corresponding to the multisetup you wish to select"
sould i set the event type to sysex or program change?
> 2. That's it!!!
> Hope this helps.
2005-09-02 by malik
p.s. i have two pictures i tried to upload but it appears this group
is out of space for shots of the dialouge please go to
http://spaces.msn.com/members/moonbase3/PersonalSpace.aspx?
_c01_photoalbum=showdefault&_c02_owner=1&_c=photoalbum
you're prolly gonna have to copy and paste that into your browser.
means
> any.
to
> > 2. That's it!!!
> > Hope this helps.
Re: [xl7] Re: programmable knobs
2005-09-02 by Aaron Eppolito
TinyURL is your friend.
Your pictures:
http://tinyurl.com/dmgdq
-Aaron
PS. your original question: bank selects and program changes are NOT
sysex.  Bank select is a controller message and program change is a
program change message.
> means
> > any.
> to
> > > 2. That's it!!!
> > > Hope this helps.
> Life without art & music? Keep the arts alive today at Network for
> Good!
> http://us.click.yahoo.com/iuUuID/dnQLAA/n1hLAA/pWZylB/TM
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
2005-09-02 by malik
thanks but now i'm lost again. so what kind of message do i send to
the mp-7 to change the multisetup?
> Your pictures:
> -Aaron
NOT
group
browser.
want
map.
number
> > means
> > > any.
channel
> > to
to "select
mail@p...>
ONE
> > > > 2. That's it!!!
manual
> > > > Hope this helps.
for
> > Good!
> > Yahoo! Groups Links
Two controller messages and a program change.
B0 00 50
B0 20 00
C0 XX
where XX is the number of the multisetup you want to select in hex.
Your MIDI program might handle bank select as part of its logical
program change mechanism, in which case, you'd just enter the 80,00,XX
parts (MSB,LSB,PC).
That said, if you're trying this stuff, I'd recommend some reading up
on MIDI.  This site is so-so, but it's probably most comprehensive:
-Aaron
>> is a program change message.
2005-09-02 by malik
thanks been to this site before will try and see if i can learn
something this time hehe. i'm goin in circles here...
> B0 00 50
> B0 20 00
> C0 XX
80,00,XX
> parts (MSB,LSB,PC).
up
> -Aaron
to
2005-09-02 by malik
in any case it seems i wont be able to use midi- to send this kind
of message. well, i could but i wouldnt be able to trigger it via
midi.
> > B0 00 50
> > B0 20 00
> > C0 XX
hex.
> 80,00,XX
> > parts (MSB,LSB,PC).
reading
> up
comprehensive:
> > -Aaron
send
> to
programmable knobs
2007-05-10 by sp808hack
Could someone please go into a little bit of detail about how to set up
the programmable knobs. Heres a list of things I want to do with the.
-Adjust the ADSR parameters of the prestets
-control the effect parameters i.e feedback, var ect
-note ranges, this would be really cool! If any one hasnt thought of
this yet imagine the possibilities i.e &(*&king with basslines.
I know it has something to do with assigning each knob to the midi
addresses of the parameter you want to control, but the manual dosent
go into much detail about this. Thanks to you, who ever you will be.
2007-05-10 by scodoha04
Page 144 of the manual.
ADSR is default to knobs 5 through 8 already.
Your other "wants" I don't think are possible at least directly from
the box. Variation of beats or LFO have no modulation destination;
sysex has a place for it though as well as changing the highs and lows
of keyboard preset assignments. You're looking at learning sysex. The
manual for that is in the files section.
how to repeat a part of a song?
2007-05-18 by Dacian Victor
Do any one know how, when you play live, to repeat for a while a part of a song????
  thanks //Daci
Do You Yahoo!?
http://mail.yahoo.com
Re: [xl7] how to repeat a part of a song?
2007-05-18 by Paul Nagle
What I tend to do is slip into pattern mode at the point I want to
repeat. It does this smoothly and you can then tweak the pattern, mute
unmute parts and so on.
Paul
"Effectus super absolutionem"
http://www.JointIntelligenceCommittee.com
http://www.myspace.com/jointintelligencecommittee
Tips for preventing patch cockups
I wonder if anyone can help? I asked this on the Proteus 2000 forum but
they suggested the expertise was over here.
I always have problems with my P25K and patches, the confusion between
patches used for patterns, songs and multis. Ideally I'd love a way to
tell it to never loads patches for songs or patterns but I don't see a
way for that.
I tend to use 32 channels - 16 for internal song and pattern stuff, 16
for use with an external sequencer (Sequentix P3). So all I want is to
load a multi that contains the 32 channels I'll need for my combined
song using both sequencers. Trouble is I frequently make a mistake, load
either a song, pattern or multi in the wrong order or save in the wrong
order and end up with my multi pointing to the wrong patches. My
problems are compounded by the fact that the P25K defaults to saving at
the last position it saved to, not the last location loaded from but I
guess that's just the way it is... :(
How does anyone else deal with this?
Also, I can change multis using remote bank select but this only seems
to respond to MIDI channel 1, which is weird. Perhaps because there is
no "multi control" channel that I can see. I keep almost giving up on
the P25K sequencer but it's so damn useful that I stick with it. I've
read the manual and it seems to imply that songs/patterns only load
patches for which tracks are assigned - but I don't find this to be
true, unless I'm doing something wrong? Iuse 1-16A for the internal
sequencer, 1-16B for external.
Any tips gratefully received,
Paul
Re: Tips for preventing patch cockups
2007-05-24 by gonzinigonz
Can you not insert a patch change message in the seq on each channel
or globally from one track to setup all your patches for the seq?
I always used to insert a bar for this purpose at the start of a
track so all the correct patches get called up.
Obviously you will have to keep the correct patches saved to the same
memory locations for this to work.
I guess this is what you mean?!
but
between
to
see a
> way for that.
16
to
combined
load
wrong
saving at
but I
seems
is
on
I've
> Paul
programmable knobs
2007-10-31 by sp808hack
I've been through this in the forums and in the manual over and over
and still can figure out how to assign the fx parameters to the
programmable knobs. I just want to be able to play the fx real time
without having to go into those bullshit menus and use the bullshit jog
wheel.
2007-10-31 by malik
then you should have bought VSTs LOL!
jog
> wheel.
2007-11-01 by steve_the_composer
I sense a bit of frustration and want to offer an alternative route to
achieve effects. Most people using the P2K synth engine think only of
FXA and FXB as effects. However, if you think of the synth engine
itself, all kinds of realtime effects can be created using the 4 x 4
knobs. Admittedly it takes a bit of programming.
I seem to recall discussions here about Wah-Wah effects, Fret-slide
effects, etc.
So far as I can recall, assigning the 4 x 4 knobs to FXA/FXB
parameters cannot be done. (Its been a while, but I may be wrong.)
--Steve
jog
> wheel.
RE: [xl7] Re: programmable knobs
2007-11-01 by craig ward
Cheers man, thats a different way of thinking about it. I'll give it a go. If anyone else has a way of adjusting the A and B effects processors with the knobs though that'd be awsome. PS you were correct about the frustration.
To: xl7@yahoogroups.comFrom: smw-mail@...: Thu, 1 Nov 2007 02:51:52 +0000Subject: [xl7] Re: programmable knobs
I sense a bit of frustration and want to offer an alternative route to achieve effects. Most people using the P2K synth engine think only of FXA and FXB as effects. However, if you think of the synth engine itself, all kinds of realtime effects can be created using the 4 x 4 knobs. Admittedly it takes a bit of programming.I seem to recall discussions here about Wah-Wah effects, Fret-slide effects, etc.So far as I can recall, assigning the 4 x 4 knobs to FXA/FXB parameters cannot be done. (Its been a while, but I may be wrong.)--Steve--- In xl7@yahoogroups.com, "sp808hack" <craigbiz@...> wrote:>> I've been through this in the forums and in the manual over and over > and still can figure out how to assign the fx parameters to the > programmable knobs. I just want to be able to play the fx real time > without having to go into those bullshit menus and use the bullshit jog > wheel.>
What are you waiting for? Join Lavalife FREE
http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Flavalife9%2Eninemsn%2Ecom%2Eau%2Fclickthru%2Fclickthru%2Eact%3Fid%3Dninemsn%26context%3Dan99%26locale%3Den%5FAU%26a%3D30288&_t=764581033&_r=email_taglines_Join_free_OCT07&_m=EXT
2007-11-05 by Aaron Eppolito
FX patchcords are in the PRESET CORDS section, not the LAYER CORDS page.  Simply hit the cords button twice.
That said, I believe that only works if you're in preset FX mode, not master FX mode.  Remember that the XL-7 is inferior to other synths in this manner � you only have 4 busses to choose from and you can't choose the send amount per channel/preset.  Put another way, the sends are always 100% to the bus, and the each of the 4 busses has a wet/dry mix.  To use this sort of setup, you have to create four different FX "amounts", then choose per channel which of those four amounts you want.
-Aaron
----- Original Message ----
Sent: Wednesday, October 31, 2007 10:01:28 PM
Subject: RE: [xl7] Re: programmable knobs
 frustration.
Do You Yahoo!?
