Global - Mix Outputs....bugged?
2005-05-18 by lelektronik
Hi i just upgraded my xl7 to 0s 2 and it's alla going fine. BUT there is a problem with the setup outputs. Say i edit a particular setup for a pattern (1a, 5a and 16a to send2->sub1 where i process the sound with a compressor and others indifferently to the other MAIN outputs like send1 and send4) and i switch to another after saving. It happens that if in the pattern after the one i edited this way the values are changing, when i return to the previous one the settings are back again in the old combination, as if i've not saved! I'll explain better: Pattern 01 global:1a - send3-main ...i' gonna edit this value and save | | | | | | global:1a - send2-sub1 ..... Ok now i save it! then....... Pattern 02 global 1a - send1-main ..... ok i'm leaving it to send1-main and go back to the pattern 01 without save anything. Pattern 01 global 1a - send1-main!!!!!! AGAIN??? WTF! It's EVEN not his first setting of send3! He got the pattern 02 value!! I managed of converting some pattern with the value i wanted but only in a very confusing attempt of not chosing patterns with other values after saving them... Anyone can tell me something? It's very important managing outputs for the tracks because i got to effect the 1a,5a and 16a and this 'bug' is making me go crazy. If i'm doing something wrong tell me also. Sorry for my english and thank you all :) LeLe
