buzz in the outputs
buzz in the outputs
2005-05-05 by gutman75
Hi all,
I've posted this question a while ago, and got no replies.
But the problem hasn't gone, and I really want to do something about it.
Any hints/tips will be greatly appreciated!
So:
- the first time I mentioned phone outputs only, but actually the buzz
is present in main outs as well;
- its' loudness is constant, not affected by master volume at all;
- this looks like a stupid grounding problem - maybe someone familiar
with the innards of a command station has an idea *where* it can be?
Cheers!
Boris.
Re: buzz in the outputs
2005-05-06 by gonzinigonz
There are grounding issues with the command stations. I had the common
problem with the headphone jack buzzzzzz.
Tighning all the screws cured the probelm (or it might of been loosen
the headphone jack nut.. or both.. cant remember)
Maybe you could try this. Its mentioned in the XL7 FAQ thats in the
files section (i think..)
How is it plugged into your studio? ie into a desk, into a computer??
(that will most proberly buzz...)
Give us a bit more info and we might be able to help you more :o)
Gonz
--- In xl7@yahoogroups.com, "gutman75" <bgutman@c...> wrote:
> Hi all,
it.
> So:
buzz
> Cheers!
> Boris.
2005-05-08 by gutman75
The command station is plugged to a mixer (Mackie 1604 for that
matter... it has its' own problems, but the buzz is definitely coming
from the MP-7). All audio equipment is powered from the same outlet
if that matters. However the buzz is also present in the headphones
plugged straight to command station's phone output. Recently was
doing something in headphones and it got really annoying - that's
when I decided I got to do something about it.
common
loosen
computer??
> Gonz
> > Hi all,
about
> it.
> > So:
> buzz
familiar
be?
> > Cheers!
> > Boris.
2005-05-08 by gonzinigonz
Taken from the FAQ in the files section..
-I have a humming sound in my headphones when they're connected to
the Command Station, is it defective?
No, the hum can actually be caused by a few things. Sometimes after
installing a new Sound ROM, the two halves of the Command Station
outer cover may not be secured tightly enough. Use a philips head
screwdriver to check that all of the screws are securely seated. Also
check to see if the headsocket itself is securely fastened to the
unit as that too may be an addition cause of the noise. Some users
have reported that using a 12v lamp plugged into the unit may
occasionally cause some minor noise in the headphones. Lastly, check
if the ribbon cable connecting the headphone circuit board to the
main circuit board has come loose inside the machine.
Check all your screws are tightened down etc
Gonz
coming
> common
> loosen
> computer??
> > Gonz
> > > Hi all,
> about
> > it.
> > > So:
> > buzz
all;
> familiar
can
> be?
> > > Cheers!
> > > Boris.
Re: [xl7] Re: buzz in the outputs
2005-05-08 by Aaron Eppolito
Unplug the MP-7 from everything except power.  See if you still have
hum in the headphones.  If you don't, try connecting things one by one
until the problem returns.  If you do have hum even when nothing else
is conneted, I'd bring the unit to a different outlet in a different
part of the house.  Try turning off halogen lamps nearby.  Also, you
could check the internal connections too, but if you're also getting
hum on the mains, it's probably not that.
-Aaron
> common
> loosen
> computer??
> > Gonz
> > > Hi all,
> about
> > it.
> > > So:
> > buzz
> all;
> familiar
> be?
> > > Cheers!
> > > Boris.
> What would our lives be like without music, dance, and theater?
> Donate or volunteer in the arts today at Network for Good!
> http://us.click.yahoo.com/rKxVKC/SOnJAA/n1hLAA/pWZylB/TM
Yahoo! Mail
Stay connected, organized, and protected. Take the tour:
http://tour.mail.yahoo.com/mailtour.html
2005-05-09 by infradead
how old is the building you're in?
maybe you have improperly grounded / dirty power..
i've had issues with that hauling my xl-7 over to friends to jam
before..  sounds great at my house but buzzes plugged into thier power..
> Hi all,
it.
> So:
buzz
> Cheers!
> Boris.
2005-05-09 by gutman75
Funny you should mention that: the studio is in the old part of house,
which is over 200 years old. At any rate, the power is notoriously bad
in our area (recently one of my hard disks died - apparently, because
of a voltage spike, so I'm going to get a UPS anyway). Could low-
quality power really be causing hum? If so, a UPS is supposed to help,
right?
Thanks a lot to all who replied!
Have a nice day,
Boris.
2005-05-09 by gonzinigonz
Bad earthing, yep causes hums..
was the problem only when you connected it to you makie mixer or did it
still do it alone with just headphones plugged in?
Like Aaron said try powering in from another socket and maybe try
another IEC mains lead.. also those multiway extension cables can be a
bit moody somethimes, if your using one?
You could buy one of those mains outlet fault testers that tells you
when you have a problem. Plug it into your mains outlet and read the
display.
Cheers
Gonz
house,
bad
help,
> right?
> Have a nice day,
> Boris.
2005-05-09 by Bob S.
Power quality, which a UPS can solve, is not the issue here.  Grounding is.
If the ground is not zero volts, that is elevated or has leakage, your
equipment will have 50/60 cycles all over the place.  Even cases of the
equipment will no longer be a shield to hum but an antenna to it.
Take some measurements against a good known ground (maybe waterpipes) with
an AC voltmeter and then possible hire an electrician to reground your
wiring system.....
Bob
Corona/Riverside, CA
To: <xl7@yahoogroups.com>
Sent: Monday, May 09, 2005 12:59 AM
Subject: [xl7] Re: buzz in the outputs
> right?
> Have a nice day,
> Boris.
