FX MODE on the MP-7 & Individual key (note) volume
2002-02-02 by mp7curt
Hello,
> I wanted to know how to have effects 'on' on some tracks and 'off'
with other tracks.  Can someone help me?
> Also, I have the volume at 127 on certain tracks and the sounds
still seem rather low.  Is there a way for me to turn volume up on
each note or an effect that would boost the output of that particular
sound.  I'm having trouble figuring out how these effects tie into
the User Presets and Sends 1-4->main.
PLEASE HELP ME!
Re: FX MODE on the MP-7 & Individual key (note) volume
2002-02-02 by mikexl7
--- In xl7@y..., "mp7curt" <curtJCpro@e...> wrote:
> Hello,
and 'off'
Go into globlal and find mix output and select the FX send you want
the sound to be track to use.  To further edit the FX just go to the
FX send amounts screen and set the mix levles of the fx for A and B.
particular
> sound.
Depending on the sound you may just want to turn all other sounds
down a little.  It is often better to turn things down rather than
up. But if you do want to make a paticular preset louder then select
the track that the preset is on and press the preset edit button and
select the AMP screen and turn up each layer up a few notches.  And
save the preset to a user location so you dont loose it.
> PLEASE HELP ME!
Read the manual a few times..
Hope that helped
Mike
Re: [xl7] FX MODE on the MP-7 & Individual key (note) volume
2002-02-04 by erik_magrini@Baxter.com
I wanted to know how to have effects 'on' on some tracks and 'off' with
>>>Check out the FAQ in the files section of this group, there's a whole
section on this. <<<
> Also, I have the volume at 127 on certain tracks and the sounds still
seem rather low.  Is there a way for me to turn volume up on each note or
an effect that would boost the output of that particular sound.  I'm
having trouble figuring out how these effects tie into the User Presets
>>>In Preset Edit mode, you can raise the AMPVOL value up to +10 for each
leyer of a Preset.  Try that, it should work. <<<
