Soundsets exactly the same as the XL-1 & MP ??
2002-02-01 by lastnightsleep
Anyone knows if the soundsets of the XL-1 is exactly the same
as the XL-7 & the Mo'Phatt is the same as the MP-7 ?
I have both Mo'Phatt & XL-1 - grrrrrrrrrr , thinkin on selling them &
buying an extended MP-7 instead .
BTW : i like the soundset of the Mo'Phatt over the XL-1
Cheers ,
Marc
Re: Soundsets exactly the same as the XL-1 & MP ??
2002-02-01 by emufreak1
They are identical,(#9062 ROM from the Mo'Phatt and #9089 ROM from
the XL-1)just with different preset for the new **-7's.
M2
http://groups.yahoo.com/group/orbit3
> Cheers ,
> Marc
RE: [xl7] Soundsets exactly the same as the XL-1 & MP ??
2002-02-03 by Panzare
I just went the same route except I swapped a 2500 for an MP-7 with
the Techno Synth ROM card. Next step is the World Expo ROM card.
Can't go wrong with that combination. That would be my suggestion if
you like the Mo Phatt sounds, you'll love the MP-7's.
Sent: Friday, February 01, 2002 12:35 PM
Subject: [xl7] Soundsets exactly the same as the XL-1 & MP ??
Cheers ,
Marc
RE: [xl7] Re: Soundsets exactly the same as the XL-1 & MP ??
Stupid question from a newbee,
To record another Track (building a pattern):
1.    Select the Track using the +Track button to left of LCD.
2.    Press Preset View, and select a new preset.
3.    Press Preset View again to return to Pattern screen.
4.    Press Stop to reset pattern to beginning, then press Record and Play
        to begin recording next track.
Ok, this works fine but the sound I selected for the new track doesn't play
until after I'm done recording and play the pattern back. The sound I hear
while creating the 2nd track is the one from Track 1, the original track.
When it plays back it does play the new presect I selected, but no while
I'm recording.
So whats the trick, since the manual seems to not mention this little
detail.
jp
  Sent: Friday, February 01, 2002 1:28 PM
  Subject: [xl7] Re: Soundsets exactly the same as the XL-1 & MP ??
  M2
  > Cheers ,
  > Marc
        Yahoo! Groups Sponsor
              ADVERTISEMENT
Nevermind....it was a stupid question. Figured it out. It was a Midi problem
on
the keyboard I'm using as a controller for the MP-7.
  Sent: Sunday, February 03, 2002 10:33 AM
  Subject: RE: [xl7] Re: Soundsets exactly the same as the XL-1 & MP ??
play
  I'm recording.
detail.
  jp
    M2
    > Cheers ,
    > Marc
              ADVERTISEMENT
Re: [xl7] Re: Soundsets exactly the same as the XL-1 & MP ??
2002-02-04 by gary saville
After you press the preset edit button, check the midi channel on the top lefthand side of the screen, make sure the channel matches the track number that you are working on
ie:
T 01 -pattern screen far left
C 01a -preset edit page far left
it should default to this, but if someone has changed your defaults multisetup it might have changed.
Gary
Sent: Sunday, February 03, 2002 8:32 AM
I'm recording.
So whats the trick, since the manual seems to not mention this little detail.
jp
M2
> Cheers ,
> Marc
2002-02-04 by Aaron Eppolito
Try turning on "RECHANNELIZE MIDI IN To Track Chan" to "always" or "on
record".  This will save you from having to change the midi channel of
your controller keyboard.  The screen is in the middle of the MIDI
menu.  If you don't have 1.18 software, you should get it from the
website!
-Aaron
PS.  look for enhancements for external gear in the coming release...
> problem onthe keyboard I'm using as a controller for the MP-7.
>      -----Original Message-----
>      From: Panzare [mailto:panzare@...]
>      To: xl7@yahoogroups.com
>      XL-1 & MP ??
>      Stupid question from a newbee,To record another Track
>      (building a pattern):1.    Select the Track using the +Track
>      button to left of LCD.2.    Press Preset View, and select a
>      new preset.3.    Press Preset View again to return to
>      Pattern screen.4.    Press Stop to reset pattern to
>      beginning, then press Record and Play         to begin
>      recording next track. Ok, this works fine but the sound I
>      selected for the new track doesn't playuntil after I'm done
>      recording and play the pattern back. The sound I hearwhile
>      track.When it plays back it does play the new presect I
>      selected, but no whileI'm recording. So whats the trick,
>      detail.Thanks,jp
>           From: emufreak1 [mailto:mmcquay@...]
>           the XL-1 & MP ??
>           and #9089 ROM from
>           **-7's.
>           M2
>           exactly the same
>           MP-7 ?
>           the XL-1
>           > Cheers ,
>           > Marc
>           Terms of Service.
>      Service.
                        ADVERTISEMENT
