Alien Audio
Alien Audio
2005-01-15 by José Sáez
Sounds from other planet !!!!
http://www.esa.int/SPECIALS/Cassini-Huygens/SEM85Q71Y3E_0.html
:-o
Jose
I'm NOT going to fix your computer.
Re: Alien Audio
2005-01-16 by steve_the_composer
Thanks for the post.  I checked out the audio and the website sounds
like BS to me. The audio clips do not sound like "The Sounds of
Titan" -- just audio couched in scientific mumbo-jumbo.
The returned radar signal (bounced back from the surface) and
converted to audio simply shows acceleration--as the craft gets
closer to the ground, the bounce back time gets shorter and shorter
according to the speed of the landing.
I suppose if you know the weight of the craft, you can use the
frequency to calculate the force of Titan's gravity relative to
earth. (Where is Charles Dodge when we need him? I would rather hear
a composer create someting like "Titans Magnetic Fields.")
I would not call the conversion of bounce back signal to audio "The
Sound of Titan."
On the other hand, the "wind" of Titan definitely tells me the moon
is pink. Clearly, that is pink noise.  8-)
--Steve_the_skeptic
> :-o
> Jose
