is it possible to use shift start times for all sequenced tracks?
>>>Yes, all Pattern based editing operations require you to select the
tracks that the editing will be applied to by arming the track mute
buttons. <<<
is it possible to use de lfos and modulators to generate pitchbend events
to the midi out [i bought an S2000]?
>>>Hmmm, not sure! I know you can obviously modulate transpose within a
Preset, but it doesn't send out any CC info to the midi out. You'd have
to record the pitchbend info onto a sequencer track by recording the
touchstrip. Then you could assign that track to EXT and have it send the
midi data out one of the MIDI outs. <<<
material from any computer.
For Translation:
