setup the xl7 to always set channel assign to ext
2004-07-08 by alternative
how can i set up the xl7 to always have all track destinations set to ext instead of int? is there some quick way to set this up on boot, or some way to restore these settings quickly? i have tried saving pattern, saving multi setup and saving setup
2004-07-08 by Wesley D
Weird little quirk here. My Arppegiator is dead when I'm set to external. As soon as I switch to internal it works, otherwise it just plays one note and sucks. Any help is appreciated. -WEsley --------------------------------- Do you Yahoo!? Yahoo! Mail - You care about security. So do we. [Non-text portions of this message have been removed]
2004-07-08 by tttsystems@earthlink.net
Check the midi clock source and it's routing to and through the XL-7 Is the source of the midi clock (recorder, other synth, etc.) set to transmit the clock externally? Is your midi signal router connecting the 2 devices and enabled for SYSEX (I think the clock is considered a sysex message to a midi switch/router)? The XL-7 should display it's calculation of the BPM of the midi clock on the from panel when set to tempo.... Bob Corona/Riverside, CA Original Message: -----------------
Date: Thu, 8 Jul 2004 15:53:51 -0700 (PDT)
Subject: [xl7] ARP not working with external clock
<html><body>
<tt>
and sucks.<BR>
Any help is appreciated.<BR>
<BR>
-WEsley<BR>
<BR>
<BR>
---------------------------------<BR>
Do you Yahoo!?<BR>
Yahoo! Mail - You care about security. So do we.<BR>
<BR>
[Non-text portions of this message have been removed]<BR>
<BR>
</tt>
<br>
<!-- |**|begin egp html banner|**| -->
<table border=0 cellspacing=0 cellpadding=2>
<tr bgcolor=#FFFFCC>
<td align=center><font size="-1" color=#003399><b>Yahoo! Groups
Sponsor</b></font></td>
</tr>
<tr bgcolor=#FFFFFF>
<td align=center width=470><table border=0 cellpadding=0 cellspacing=0>
<tr> <td align=center><font face=arial size=-2>ADVERTISEMENT</font><br><a
href="http://us.ard.yahoo.com/SIG=129g2g0r2/M=273541.4247512.5496808.2248467
/D=grplch/S=1707709865:HM/EXP=1089413634/A=2061551/R=0/SIG=11sr5b9n1/*http:/
/launch.yahoo.com/artist/videos.asp?artistID=1001301" alt=""><img
src="http://us.a1.yimg.com/us.yimg.com/a/la/launch/122603_LREC_bkup_BR_Ashan
ti.jpg" alt=" " width="300" height="250" border="0"></a></td></tr></table>
</td>
</tr>
<tr><td><img alt="" width=1 height=1
src="http://us.adserver.yahoo.com/l?M=273541.4247512.5496808.2248467/D=grplc
h/S=:HM/A=2061551/rand=895825352"></td></tr>
</table>
<!-- |**|end egp html banner|**| -->
<br>
<tt><hr width="500">
<b>Yahoo! Groups Links</b><br>
<ul>
<li>To visit your group on the web, go to:<br><a
href="http://groups.yahoo.com/group/xl7/">http://groups.yahoo.com/group/xl7/
</a><br>
<li>To unsubscribe from this group, send an email to:<br><a
href="mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe">xl7-unsubs
cribe@yahoogroups.com</a><br>
<li>Your use of Yahoo! Groups is subject to the <a
href="http://docs.yahoo.com/info/terms/">Yahoo! Terms of Service</a>.
</ul>
</tt>
</br>
</body></html>
mail2web - Check your email from the web at
http://mail2web.com/ .2004-07-09 by Aaron Eppolito
The XL-7 does not freewheel. If you're not sending it clock all the time, it's essentially stopped (tempo is 0). Some sequencers send clock all the time, some only when they're playing. You'll need to use one that sends all the time or else your arps (and tempo based FX and beats, etc) will not play when stopped. -Aaron --- Wesley D <Serfiss@...> wrote: > Weird little quirk here. My Arppegiator is dead when I'm set to > external. As soon as I switch to internal it works, otherwise it > just plays one note and sucks. > Any help is appreciated. __________________________________ Do you Yahoo!? Yahoo! Mail - 50x more storage than other providers! http://promotions.yahoo.com/new_mail
2004-07-09 by Wesley D
was sequencing it with Sonar. I've since fixed the problem. the wierd part is that is was working, as in getting tempo info, but the arp wouldn't play. Then upon tweaking no tempo info was getting sent at all, then I switched sonars sync option from audio to internal. seems to have been a glitch, sonar bugged out for minute, it's been doing that lately. I want Logic. now I'm trying to figure out how to get the ARP recorded as notes. I've got the transmit option enabled, yet still my oh, snap, it's cuz I'm using a controller which is being recorded and the ARP info would come straight from the EMU. So what is the best way to record arp info? send the controller to the emu and record everything from the main midi out? i'm gonna have to try this... Thanks! Wesley --------------------------------- Do you Yahoo!? New and Improved Yahoo! Mail - Send 10MB messages! [Non-text portions of this message have been removed]
2004-07-10 by alternative
i have noticed the EMU won't save the midi routing settings in an empty pattern. It won't save the routing of "empty" tracks... hmmz. When you put data on a track it seems allright regards, roel ----- Original Message ----- From: "alternative" <alternative@...> To: <xl7@yahoogroups.com> Sent: Thursday, July 08, 2004 9:51 PM Subject: [xl7] setup the xl7 to always set channel assign to ext > how can i set up the xl7 to always have all track destinations set to ext > instead of int? > is there some quick way to set this up on boot, or some way to restore these
> settings quickly? > > i have tried saving pattern, saving multi setup and saving setup > > > > > > Yahoo! Groups Links > > > > > >
2004-07-12 by erik_magrini@Baxter.com
Hmm, maybe make those changes and save the current multisetup? I'm
actually not sure if multi's remember track routings or not, but that
would be my first choice if they do.
alternative <alternative@...>
07/08/2004 02:51 PM
Please respond to xl7
cc: Subject: [xl7] setup the xl7 to always set channel assign to ext how can i set up the xl7 to always have all track destinations set to ext instead of int? is there some quick way to set this up on boot, or some way to restore these settings quickly? i have tried saving pattern, saving multi setup and saving setup Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
2004-07-12 by alternative
Set up the XL-7 for step recording, pushing the record-button three times. Then select the track you wish to save the routing for. Turn any of the knobs on the left (regardsless quickedit, program., volume or pan) and switch to the next track, and so on. This pattern can then be saved, as will the routing for the pattern (though there is actually no data on the tracks). Regards, Roel ----- Original Message ----- From: <erik_magrini@...> To: <xl7@yahoogroups.com> Sent: Monday, July 12, 2004 4:06 PM Subject: Re: [xl7] setup the xl7 to always set channel assign to ext > Hmm, maybe make those changes and save the current multisetup? I'm > actually not sure if multi's remember track routings or not, but that > would be my first choice if they do. > > rEalm > > > > > > alternative <alternative@...> > 07/08/2004 02:51 PM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: [xl7] setup the xl7 to always set channel assign to ext
> > > how can i set up the xl7 to always have all track destinations set to ext > instead of int? > is there some quick way to set this up on boot, or some way to restore > these > settings quickly? > > i have tried saving pattern, saving multi setup and saving setup > > > > > > Yahoo! Groups Links > > > > > > > > > > > The information transmitted is intended only for the person(s)or entity > to which it is addressed and may contain confidential and/or legally > privileged material. Delivery of this message to any person other than > the intended recipient(s) is not intended in any way to waive privilege > or confidentiality. Any review, retransmission, dissemination or other > use of, or taking of any action in reliance upon, this information by > entities other than the intended recipient is prohibited. If you > receive this in error, please contact the sender and delete the > material from any computer. > > For Translation: > > http://www.baxter.com/email_disclaimer > > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > >
2004-07-12 by Aaron Eppolito
This is the easiest way to set up a "template" pattern. Do be careful though, it actually IS saving the data you've step recorded at tick 0, but the list editor hides it from you. I'd recommend either step recording a pan event of 64 (center) or volume at 100, as both of these will get overwritten with real values when you save the pattern. -Aaron --- alternative <alternative@...> wrote: > Set up the XL-7 for step recording, pushing the record-button three > times. Then select the track you wish to save the routing for. Turn any > of the knobs on the left (regardsless quickedit, program., volume or pan) > and switch to the next track, and so on. > This pattern can then be saved, as will the routing for the pattern > (though there is actually no data on the tracks). > > Regards, Roel > > ----- Original Message ----- > > how can i set up the xl7 to always have all track destinations set > > to ext instead of int? __________________________________ Do you Yahoo!? Yahoo! Mail Address AutoComplete - You start. We finish. http://promotions.yahoo.com/new_mail
