diagnostics
2002-01-24 by mikexl7
hey Aaron is there a list of what the diagnostics mode can do other then what is said here? Any other handy stuff in there? Mike "If you don't have any user presets that you've edited (or have backed up any presets that you changed) you could reinitialize user data. Boot into diagnostics (hold two cursors when you power up) and select "17 Init Data Except Seq". Make sure you DO NOT select "16 Initialize User Data" as you will lose ALL SEQUENCES. -Aaron "
