With the Yamaha (rm1x) you can send song select commands and it will change
the pattern that's playing. If you have the 'quantise' set to 1, then it
will change at the end of the current bar.
Stu
|-----Original Message-----
|Sent: 04 June 2004 20:11
|To: xl7@yahoogroups.com
|Subject: [xl7] Re: midi trig again
|I'm not sure what other sequencers I would put in the same class as
|the ComStat, but the Electribes can queue patterns via MIDI and the
|Roland MC's have the RPS feature (trigger single track) but no MIDI
|queueing. I'm not sure if the Akais can select patterns over MIDI but
|they definitely don't do RPS; I don't believe the Yamahas will do
|either. I'd double-check the RS7k and MPC manuals though.
|--- In xl7@yahoogroups.com, "Matt Picone" <matman@m...> wrote:
|> I really wish the xx-7 had the ability to trigger/queue patterns
|from
|> midi notes. Does any other sequencer in its class have this feature?
|> -m@
|Yahoo! Groups Links
