More for Heinrich
2002-01-23 by erik_magrini@Baxter.com
Heinrich, don't worry mate we're getting there! It can be frustrating I know, but this is just the way iot is sometimes when working on electronic music, especially when you bring a computer into the picture. If nothing else, think how much you're learning! Ummm, ok that was lame I'll admit it. :)
So, to help me narrow this down, I guess I need to understand what you're doing a bit more. We know WHAT the problem is now, we just need to figure out how it's happening. Are you writing the patterns in Cakewalk (which version BTW) and then savin the patterns as SMF"s to be loaded via E-loader into the MP-7? Or are you writing the parts in the MP-7 and then having problems once you get it in Cakewalk? Consider me dense (shouldn't be too hard) and walk me through your process of writing.
Thanx, just trying to understand completely what you're doing,
So I checked the bars where notes are missing and found that notes that usually have the same position in
the bar, have moved to a different position in the bar with the "missing" notes. Instead of - say - 14/1/32 - 14/2/32 - 14/3/32 - 14/4/32 they went: 14/1/32 - 14/2/32 - 14/2/232 - 14/2/238 - I moved them to the right
position to see if it works - it does! But the velocity still was very low and I had to fix that as well.
Final point: Cakewalk played back fine while recording on the mp-7, but the recorded results are moved notes with changed velocity in some bars, but sometimes just as well missing notes.One hint: Before I recorded the pattern I actually copied a formerly recorded pattern to an empty pattern, just to have the settings, then cut track 1 to clipboard to delete it, then record a new pattern on track one. Is it possible that some information (except the settings sure enough) still remains on the track when cutting it to clipboard? Could these bits and pieces disturb the newly recorded track?
Sorry for the long posting. Maybe somebody knows whats going on here.
I am so tired with all this fixing and asking. I can´t make music
like that. I´m close to moving over to a simple machine thats working
at least for me.
Any suggestions are welccome.
