This is because the one you switched back to is in the "edit buffer."
This is a known bug and will be fixed in the next release. For the time
being, if you save then revert, it will get better.
-Aaron
erik_magrini@... wrote:
> They reason the second pattern's Presets remain when you switch back,
> is because there's no new Program Change commands in the first pattern
> since those tracks are empty. I think the lags in Song mode are due
> to something else, but it is known by Emu.
> rEalm
> "alexfrano" <afrano@...>
To:
01/22/02 01:12 PM xl7@yahoogroups.com
Please respond to xl7 cc:
Subject: [xl7] track
enabling
> Hi there. I am now using the v 1.18 OS in my XL-7. I still have
> small problems, one of them being the following:
> I have a user pattern that does not use all tracks, I change patterns
> to one that uses all tracks, and then I go back to my first pattern,
> the channels (presets) assigned to each track that is not used
> changes to the presets or assignation of the second pattern. This
> apparently presents no problem, since there are no events in the
> tracks that change their assignation. Nevertheless, when I build the
> song, the secuencer jumps or lags between each pattern. This is
> because, it has to read the new assignation. Anyways, I dont find
> that normal. What do you think??
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
