Re: [xl7] my final round with the mp-7
2002-01-22 by erik_magrini@Baxter.com
Go into Note List edit and look at the velocities and note lengths of the notes that aren't playing back. Are the velocities too low, or the note lengths too long? Also, the HH's typically use a feature called Assign Group to allow open HH's to turn off closed HH's (although it has many more uses than just this). Check on page 178 of the manual to see what I'm talking about. Go into the Preset Edit mode for the Drum Preset that's giving you the trouble,a nd check to see if that HH is assigned to a mono group. That would explain why the note is silent, even though you can still see it. Check to see if you've got other drum sounds at the same locations as the quiet notes, my guess is that this is what your problem is.
I recorded a mididrumfile from cakewalk sonar on track 1 of the mp-7.
It contained - besides the kick, snare and some percussion - a
hihat and cymbal pattern with 16th. The file is definitely not
overloading the track, thers not much happening. Quantize during
recording was set to "off". Playing back the unrecorded file was no
problem at all. But after I recorded it, there are notes of the hihat
pattern without sound. On some part of the pattern only one. On other
parts more. No matter how often I tried this - allways the same notes
do not sound. When I play back the recorded file very slowly I
realize, the midi note seems to be there (or was it just a controller
event?), because I can see the green light on, but the sound of this
note is missing. I altered the quantize setting when I was playing
back the file from 16 to 32. But still the same. I changed the preset
kits - still the same problem. Is it a bug? I don´t think so, because
its so "regular". Did I miss something?
Any help is appreciated. I spent a lot of time last night in trying
to solve
this.
Heinrich
