Patches won't change!!!
2004-04-05 by donegalpunk
Somebody tell me this is obvious... I'm sending MSB LSB and Program change info to the xl-7, using it as a sound module. The problem is that both the MSB and LSB change appropriately, but the program change won't work! HELP! respond to donegalpunk@...
2004-04-06 by erik_magrini@Baxter.com
Are you sure you're sending the PC on the same MIDI Channel? I know
obvious, but I can't think what else it might be....
donegalpunk <donegalpunk@...>
04/05/2004 03:50 PM
Please respond to xl7
cc: Subject: [xl7] Patches won't change!!! Somebody tell me this is obvious... I'm sending MSB LSB and Program change info to the xl-7, using it as a sound module. The problem is that both the MSB and LSB change appropriately, but the program change won't work! HELP! respond to donegalpunk@... Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
2004-04-06 by Turby Schmidt
It works fine with cubase... there are some xml files in the files section, if you use cubase, you could see how they are built and if you do it that way it should work fine, of course you have to enable accept program change in the global menu msb-lsb-prg.no. Turby >From: "donegalpunk" <donegalpunk@...> >Reply-To: xl7@yahoogroups.com >To: xl7@yahoogroups.com >Subject: [xl7] Patches won't change!!! >Date: Mon, 05 Apr 2004 20:50:01 -0000 > >Somebody tell me this is obvious... > >I'm sending MSB LSB and Program change info to the xl-7, using it as >a sound module. The problem is that both the MSB and LSB change >appropriately, but the program change won't work! > > >HELP! > >respond to donegalpunk@... > _________________________________________________________________ The new MSN 8: smart spam protection and 2 months FREE* http://join.msn.com/?page=features/junkmail
2004-04-06 by donegalpunk
the support guys at EMU are not the most helpful in the world. I performed a hard reboot on the XL7 and then it worked, go figure. All the settings were correct before the reboot--must've been some other issue that was corrected in the restart. The only change I have to account for is the fact that the patches in the XL& patch numbers start at "0" instead of one. thanks for the help --- In xl7@yahoogroups.com, "Turby Schmidt" <trabantmusic@h...> wrote: > > It works fine with cubase... > > there are some xml files in the files section, if you use cubase, you could > see how they are built and if you do it that way it should work fine, of > course you have to enable accept program change in the global menu > > msb-lsb-prg.no. > > Turby > > >From: "donegalpunk" <donegalpunk@y...> > >Reply-To: xl7@yahoogroups.com > >To: xl7@yahoogroups.com > >Subject: [xl7] Patches won't change!!! > >Date: Mon, 05 Apr 2004 20:50:01 -0000 > > > >Somebody tell me this is obvious... > > > >I'm sending MSB LSB and Program change info to the xl-7, using it as
> >a sound module. The problem is that both the MSB and LSB change > >appropriately, but the program change won't work! > > > > > >HELP! > > > >respond to donegalpunk@y... > > > > _________________________________________________________________ > The new MSN 8: smart spam protection and 2 months FREE* > http://join.msn.com/?page=features/junkmail
