Flanging effects
2004-04-03 by Christoph Kluxen
Hi, layering the same synth sounds always cause flanging effects, how can I change? Christoph -- +++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++ 100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz [Non-text portions of this message have been removed]
2004-04-03 by steve_the_composer
--- In xl7@yahoogroups.com, "Christoph Kluxen" <pocketd@g...> wrote: > Hi, > > layering the same synth sounds always cause flanging effects, how > can I change? > > Christoph I never noticed this. Let me make sure I understand what you are ssaying: When you copy L1 to an empty layer (say L2, for example), you get a flanging effect that wasn't there before without changing any other parameters?
2004-04-03 by Turby Schmidt
> > layering the same synth sounds always cause flanging effects, how > > can I change? > > Christoph Hm, the same efect like recording with a multitrack and listen to source and recorded track at the same time? Normally you copy a layer to make variations like pitch offset, if youd use 2 identical tracks - whats that for? Anyway - you could apply a little delay offset to one of the layers [if it is a one shot sound, otherwise you might get a chorused efect] Turby _________________________________________________________________ STOP MORE SPAM with the new MSN 8 and get 2 months FREE* http://join.msn.com/?page=features/junkmail
2004-04-04 by Ravi Ivan Sharma
try a slight detune and maybe a little panning
Sent: Saturday, April 03, 2004 5:29 AM
Subject: [xl7] Flanging effects
change?
Christoph
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[Non-text portions of this message have been removed]2004-04-04 by steve_the_composer
I tested a square wave on a P2K synth engine E-Mu [XL-1]. Sure enough, when I got rid of any chorus/flange/other possible causes of auditory shift [effects processor, filter, chorus, patchcords, etc.] and doubled the layer, successive key presses demonstrated harmonic variation in the note played. It sounds like there is some phase shift between the two lawyers at the instant each layer is turned on. If there was any drift between the two layers once the note sounded, my ears couldn't hear it. Maybe that's why E-Mu synth sounds are so phatt! I am not sure if that's what you meant by flanging effect or not. Hope this helps. --Steve_the_purist --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...> wrote:
> --- In xl7@yahoogroups.com, "Christoph Kluxen" <pocketd@g...> wrote: > > Hi, > > > > layering the same synth sounds always cause flanging effects, how > > can I change? > > > > Christoph > > I never noticed this. Let me make sure I understand what you are > ssaying: When you copy L1 to an empty layer (say L2, for example), > you get a flanging effect that wasn't there before without changing > any other parameters?
2004-04-05 by erik_magrini@Baxter.com
Have you checked that the pitch and fine pitch parameters are set to 0 for
both layers, and that Chorus is off?
My breasts will glistening with sweat awaiting your response,
"Christoph Kluxen" <pocketd@...>
04/03/2004 04:29 AM
Please respond to xl7
cc: Subject: [xl7] Flanging effects Hi, layering the same synth sounds always cause flanging effects, how can I change? Christoph -- +++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++ 100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz [Non-text portions of this message have been removed] Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
2004-04-05 by Mark Fitt
>rEalm
LOL....
Mark.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.648 / Virus Database: 415 - Release Date: 31/03/2004
[Non-text portions of this message have been removed]2004-04-05 by dj 61
I've gotten this effect when linking same or similar drum kits. I have not really noticed it on other things, but the drums can create a definate flange. What presets and instrument layers are you using? Here's a towel and a be, rEalm _____ I I I I be """"" alright so the towel could use some work.. --- In xl7@yahoogroups.com, Mark Fitt <mark@t...> wrote:
> > >My breasts will glistening with sweat awaiting your response, > >rEalm > > LOL.... > > Mark. > > ---------- > > > --- > Outgoing mail is certified Virus Free. > Checked by AVG anti-virus system (http://www.grisoft.com). > Version: 6.0.648 / Virus Database: 415 - Release Date: 31/03/2004 > > > [Non-text portions of this message have been removed]
2004-04-06 by Christoph Kluxen
you are right I used different Fine Pitch, cause trying to simulate PWM by
the Audity PWM Waves, but I
remembered it using a layer one octave deeper, too
Thanx,
Christoph
04/03/2004 04:29 AM
cc: Subject: [xl7] Flanging effects Hi, layering the same synth sounds always cause flanging effects, how can I change? Christoph -- +++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++ 100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz [Non-text portions of this message have been removed] Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed] Yahoo! Groups SponsorADVERTISEMENT ------------------------------------------------------------------------ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/xl7/ * To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. -- +++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++ 100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz [Non-text portions of this message have been removed]
