live show soon, need help!
2004-03-31 by joshua langberg
Heya Everyone,
Ok, I have a show coming up on Friday in Worcester, MA.
I have been doing all of my sequencing in logic 6, thinking that I
could tranfer the sequence to the xl7, so I won't have to use a
computer. I am using a G5 and I couldn't get the e-loader program to
transfer the file under os9. So I then played the sequence from
logic, and recorded it into a blank song on the xl7 the old fashoned
way. My set is psytrance with hints of techno and industrial so I
have the song set up as one continuous sequence, which will keep me
from having to switch songs off beat. I find to my dissmay that the
xl7 will only hold 999 meauses in a song. My set has around 2000...
Plan B is to load the set into the e6400 ultra sequencer and use the
xl7 as a slave.
(unless someone knows how to use bigger sequences on the xl7) What I
really need to know is this,
When the xl7 is a slave can I route the MIDI so that I can use the
volume and pan functions live for all internal and external channels?
and is there a way to set it up, so the channel lights will flash on
external channels (triggering other gear) without any sound coming
out of the xl7?
I want to use this as a reference to see which channels are being
triggered on my microwave xtk.
This is what my setup is:
Channels 1-8 xl7 drums
channel 9 xtk bass
channel 11 e6400 ultra
channel 12 super jupiter mks/mpg80
channel 13 xtk synth
channel 14 xtk synth noises
channel 15 syntecno teebee
Any help asap would be greatly appreciated!!!!!!!
Thanks a bunch,
-Josh Langberg
p.s. if anyone is interested the info for the event is
http://www.portaltechnology.org
Re: live show soon, need help!
2004-04-01 by robotchas
It will take some work, but for best results I recommend chopping up
your song into sections of no more than 32 measures (less if the
section just loops) and recording each section into the XL-7 as a
separate pattern. Then you can step through the patterns at will,
which will also give you more control over your live set. A single
backing sequence might be easier (just press play and go), but it's
much less flexible and this is live music after all - flexibility is
important because you never know until you get there exactly how
things are going to go. Some parts of your set might need to be longer
than you thought, others might need to be dropped entirely. If you're
just playing a single sequence, you don't have the option of changing
these things. Plus, a live "remix" is just more fun to watch.
I don't think external channels will blink, but in a pinch you could
set the internal sound to a preset which made no noise, and set the
track output to "both"...that should work but you might also need to
make a different silent preset for each external patch number so your
program changes will work...
Posted while away from my ComStat, so no promises.
> out of the xl7?
> channel 9 xtk bass
> Thanks a bunch,
> -Josh Langberg
