Although it should be pointed out that the Quick Edit knobs will be
controlling either Gate Time or Velocity if you stay in Grid Record mode,
just a heads up.
retbah is correct. Press & hold play and hit rec. Also, just so you
know, you don't even have to leave record mode at all if you don't want
to. You can go in and tweek a preset (and save it!) without even
punching out. Then, just exiting the editing mode you're in will bring
you back to grid edit.
-Aaron
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
http://taxes.yahoo.com/filing.html
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
