PX-7 wobbly
PX-7 wobbly
2004-03-27 by metalflakk
Just a quick question, does anyone else's command station wobble from side to side when
you press the pads? Will E-mu fix this under warranty?
Also, mine spontaneously turns itself on every so often....but I guess that's to be expected.
=J=
Re: PX-7 wobbly
2004-03-27 by dj 61
Sounds like you might be missing a rubber pad from the bottom. If it
wobbles it should be obvious where the problem is by turning it
over. I assume you have tried setting it on different surfaces. As
for the turning on, you must be using the soft switch and not the
hard switch on the back, correct?
If the power in changes and the hard switch is still on then it will
come on. For example if you turn on an off your surge protector or
unplug and replug the unit. If you are not doing any of these things
you may want to make sure that your power flow is regular (no surge
or fault)
--- In xl7@yahoogroups.com, "metalflakk" <metalflakk@y...> wrote:
> Hi,
> =J=
Re: [xl7] PX-7 wobbly
2004-03-29 by erik_magrini@Baxter.com
to side when you press the pads? Will E-mu fix this under warranty?
>>>Yeah, mine did this a little bit too. I just glued a thin piece of
rubber on the bottom of one of the rubber feet to correct this. <<<
>>>NO that shouldn't happen! <<<
material from any computer.
For Translation:
