Shit, i just installed new ROMs and now my MP7 is freakin up. if i save
patterns, it does not save all the instruments as it has this far..
actually, when i turn my MP7 off, it replaces the first 2 channels (1&2)
with 111(0) prc:Kix 2/ MP7 ROM (channel 1) and 114(0) prc:Snares 3/ User
sounds (channel 2)
>>>Everytime you power on the XX-7, it will revert to the last Multisetup
you had loaded, NOT the last pattern. also, make sure you have Patch
changes enabled on the MIDI Menu too. <<<
Also i'm havin problems with E-loader 1.1. i'm using Windows 2000 and
edirol um-1 usbmidi port, when i try to save my pattern, it tries to save,
but then informs that "saving of file "xx" failed"? why this also?
>>>>Sadly, this could be due to any number of things, but probably it
caused by your midi port. There will be no update to E_Loader. <<<
material from any computer.
For Translation:
