erase all patterns
erase all patterns
2004-03-25 by sebastien robin
Hello,
is there a way to erase all patterns of a user bank instead of
copying 128 times an empty sequence ?
Re: [xl7] erase all patterns
2004-03-25 by erik_magrini@Baxter.com
Yeah, check the files section:
http://launch.groups.yahoo.com/group/xl7/files/Command%20Station%20Data/
And download the "XX7Initiated.zip" file (it's the last one).  Unzip it,
launch E-Loader, and load all of those Patterns into the right pane of the
sequence downloader.  By default, these will all go to Bank 0, so if you
don't want this Bank to be the one you want cleared, select all the
Patterns (CTRL+A) and then press CTRL+I and set the bank to what you want.
 Then just download them all to the XX-7!  Sounds more convuloted than it
is.
"sebastien robin" <sebastien_robin@...>
03/25/2004 02:29 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] erase all patterns
Hello,
Yahoo! Groups Links
material from any computer.
For Translation:
2004-03-27 by wayne parch
boy...don't know if you got the answer already ...but it came in to my regular e-mail but here is what you do....
1.go to  pattern edit menu...
2.scroll to erase patterns  put the curser to the bottom then scroll to the left ....(the red light will flash)
3. hit enter...everything done before will be erased! once you do that; you have to save the pattern after you have erased it.....(tracks that were used will still light up red even though they were erased) to get rid of that (those red lights) go back to the pattern edit menu   and then scroll all the way to the right to where it says....."revert to saved pattern"
(curser at the bottom hit enter) and that will get rid of all the tracks (red lights) that were used before.  and now you should have a clean track..
is.
03/25/2004 02:29 AM
        cc:
Hello,
Yahoo! Groups Links
For Translation:
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
Do you Yahoo!?
Yahoo! Mail - More reliable, more storage, less spam
2004-03-29 by erik_magrini@Baxter.com
You can do the same thing you describe by holding DELETE + The track mute
button for the track you want to erase BTW. Much faster.  :)
"wayne parch" <wparch@...>
03/26/2004 10:13 PM
        cc:
        Subject:        Re: [xl7] erase all patterns
pattern"
track..
is.
03/25/2004 02:29 AM
        cc:
Hello,
Yahoo! Groups Links
For Translation:
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
For Translation:
