Effect in presets ?
Effect in presets ?
2004-03-19 by sebastien robin
Hello,
apparently it is possible to save the effect amount for each preset.
How can you do it ?
Thank you
Re: [xl7] Effect in presets ?
2004-03-19 by erik_magrini@Baxter.com
Yes, you need to set the effects to be controlled by the "Preset On
Channel X" in the Global menu.  Then you can go into the Preset Edit menu
and specify those settings.  Now, whenever you change the Preset on that
channel ("X" in the above example) the effects will change and the send
amounts too.  This method is really geared towards people using the
Command Stations to play only one sound at a time, while the "Use Master
Settings" tends to work better if you're making your own patterns and
using multiple tracks.  Take a look at the FAQ for a better explaination.
"sebastien robin" <sebastien_robin@...>
03/19/2004 04:11 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Effect in presets ?
Hello,
How can you do it ?
Thank you
Yahoo! Groups Links
material from any computer.
For Translation:
2004-03-19 by Christoph Kluxen
Hi rEalm,
Yes, you are right, but I always have the problem that the effects are
already on although they are set to
zero in the effects preset, what´s that?
Christoph
+++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++
100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz
